Hamilton did this with a number of Grade 936 and 937 movement from within the first 2000 serial numbers that were remaining in inventory after a few years, adding 30,000 to the original number to renumber them into the 30,001-32,000 range which was then not used for other production. This made the watches seem more in line with the serial numbers of their current production. Approximately 20% of the Grade 936 and 937 production in the first 2000 serials was renumbered in this way.
It was a decent plan to disguise aging inventory, but aesthetically the open faces didn’t come out as nice looking due to the location of the case screw causing a need to split the placement of the added digits as seen with your watch.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
