Unusual Mido chronometer
Discussion in 'Wrist Watches' started by Roy Horrorlogic, Nov 21, 2019.
  1. Roy Horrorlogic
    Roy Horrorlogic Registered User
    Mar 7, 2017
    326
    73
    I just acquired this interesting watch using an ETA 2790. Unfortunately someone had managed to lose the back plate. My assumption is that I'm more likely to find a Dodo egg than a replacement. As a quick and dirty fix I've fitted a low rise UB crystal with a regular claw. It's very firm as the threads and the underlying gasket hold it pretty securely.
    Of course if someone has a back plate lying around...
    Roy
    pmwas and viclip like this.
  2. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    3,494
    210
    watchmaker
    Have you measured the case back? Is it a screw down or snap on type?
  3. Roy Horrorlogic
    Mar 7, 2017
    326
    73
    Thanks.
    it's a screw fitting with a gasket underneath. I fitted a 286 UB squeezing a little with a claw. If there was a fair chance of finding a replacement I'd take it out again and re- measure but its a snug fit and the only low rise 286 I have at the moment.
    BTW I was unable to log back into the forums with what was definitely the correct PW. I re-registered the same PW subsequently... odd.
    Roy
  4. roughbarked
    Dec 2, 2016
    3,494
    210
    watchmaker
    You have fitted a crystal. The meaurements you now need are for the case back. I can assure you that there will be one out there somewhere rhough it may not be branded Mido.
  5. Roy Horrorlogic
    Mar 7, 2017
    326
    73
    As far as I recall the internal measurement I took with calipers was 286. Hence the 286 UB. I actually have dozens of scrap watches and cases but if I have a back that would fit it would probably be branded Timex... A back that fits would need to be blank or else a Mido. And there's the question of thread pitch too - I doubt that there's a "standard".
    Roy
  6. roughbarked
    Dec 2, 2016
    3,494
    210
    watchmaker
    Which is why measurements and observations are all important.
