Unusual French Portico Clock Dial
roman16
Mar 4, 2006
121
I was following an early French Portico clock at an auction recently by Lepine. A very fine quality early clock. I've attached a picture of the dial for opinions. It has a combination of Arabic and Roman numerals. Anyone out there ever see this application before? Any explanation or opinion? Thanks
15,633
2,137
That is odd. With clocks you never know what you might see next! Willie X
zedric
Aug 8, 2012
1,841
354
It’s not that unusual with older French clocks. One set of numbers for the hours, the other for the minutes..
Reactions: Jmeechie
jmclaugh
Jun 1, 2006
5,487
285
Devon
Nice looking clock. While plenty used Arabic numerals for the minutes and Roman for the hours I don't recall ever seeing one that mixed Arabic and Roman numerals or used both together (X2) for the hours.
zedric
Aug 8, 2012
1,841
354
Didn’t notice the X2/V2 first time around.. there are lots of dials with 24 hour and minute notations, but haven’t seen that before.. Maybe just after the 10 hour revolutionary dials they experimented a bit…
Chris Radano
Feb 18, 2004
4,073
358
Pennsylvania
Reactions: Ralph
WIngraham
Apr 19, 2019
195
62
34
A beautiful clock that I was watching closely. I read that Lépine developed this dial, apparently the numeral 1 was circled to create balance with the numeral 11. With the other numbers, the overall effect is great. I've only seen this dial on a watch, I am linking an example to one at the British Museum dated 1788. Their description of the watch describes the dial as well.
Will
Reactions: Chris Radano
Chris Radano
Feb 18, 2004
4,073
358
Pennsylvania
Well I really don't know much about the maker. The dial is signed Horologer Du Roi.
So the example in the above link, says he took the title Horologer Du Roi after forming a partnership with Claude-Pierre Raguet in 1792. Which would suggest to OP clock was post 1792.
But reading the "item overview" in the above link, it says Lepine was Horologer Du Roi after 1784.
So it is likely the OP clock dates to the late 18th c.
I will have to read Robert's NAWCC articles.
But apparently, the dial is Lepine doing something aesthetically different to be more interesting.
The OP clock looks like it has an unusual pendulum suspension. So I wonder what type of escapement the clock has.
Jmeechie
Dec 8, 2010
478
126
Interesting Dial! It almost strikes me as we were trying to design a new way of dial numbering? Numbers 7, 8 and 12 are half Roman and half Arabic in the Roman style yet 4, 5 are completely Roman and 9 is Arabic and upside down in comparison to the other numerals!
Its almost as if we were showing dial design capabilities, a visual catalog, or what could be applied to a dial? The dial seems to be broken down into 1/4’s 1st Arabic, 2nd Roman, 3rd hybrid addition?, 4th hybrid ? The 9 is the odd one as the dial is also broken into upper and lower half as 9 through 3 are heads out and 4 through 8 are bottoms out! Imagine the confusion of 6 and nine if it was all Arabic with 6 bottom out and 9 head out! You’d have 6 o’clock 4 times a day!
Anyway, just my thoughts and a defiantly unique dial!
Cheers,
James
Levi Hutchins
Oct 21, 2012
134
26
To me, it looks to be a purely aesthetically-driven venture to achieve symmetry in weight for visual balance. (The "I" needed more weight, and so the oval surrounding it.)
Note the "V" and the "IV" with the thicks and thins reversed (as opposed to the normal treatment of the thicks and thins of the "V3" and "V2" opposite, the "V's rendered as mirror images of themselves.
jmclaugh
Jun 1, 2006
5,487
285
Devon
Worth noting that makers would typically have bought dials in as opposed to making their own.
Lepine was maker to Louis XV 1756, then Louis XVI and later Napoleon (I). After the revolution of 1789 nobody would have used the title Horloger du Roi for obvious reasons though I don't know when it was resurrected.
Levi Hutchins
Oct 21, 2012
134
26
Lépine was maker to Louis XV 1756, then Louis XVI and later Napoleon (I). After the revolution of 1789 nobody would have used the title Horloger du Roi for obvious reasons though I don't know when it was resurrected.
There is a current auction for a clock with similar mixed numbering - "... the Arabic and Roman numerals designed by Lépine and the dial enameled by Joseph Coteau." ... "Begun in September 1774 (according to an inscription on a spring), it was delivered around 1789-1790, during the Revolution, after the words "du roy" were deleted from Lépine’s dial—an ominous sign considering what became of Louis XVI, the clockmaker king."
Lépine... t
ransferred his business several times until 1789 when it moved to 12 Place des Victoires. By this time the running of the business was in the hands of his son-in-law, Claude-Pierre Raguet-Lépine (1753-1810), who had joined Lépine in 1783. Joseph Coteau who was known as a leading enamellist and creator of the finest French clocks - intricate enamel work and detail were a characteristic feature of his work; he is responsible for the moon phases and signs of the zodiac on this clock.
[Jean Antoine Lépine (1720-1814) - Mantel clock]
Joseph Coteau (1740-1801) - The most renowned enameler of his time, he worked with most of the best contemporary Parisian clockmakers...[/url]
Reactions: Ralph
jmclaugh
Jun 1, 2006
5,487
285
Devon
The most celebrated French dial enamelers of this period were Coteau, Merlet and Dubuisson. One source mentions a dial for a decimal clock by the latter which displayed decimal and normal time.
Chris Radano
Feb 18, 2004
4,073
358
Pennsylvania
Wow, what a fantastic clock :cool: Really great condition and great quality :thumb:. I didn't have an 18th c. pendule de Paris movement, and this is a good one. Movement plates are 5" in diameter. The escapement is a type of dead beat, the teeth resemble a Brocot. The pendulum bob is filled with small sized shot. Looks like a keeper.
Sorry the pics were taken in the garage, we have a bit of rain today.
DSCN7589.JPG DSCN7590.JPG DSCN7591.JPG DSCN7592.JPG DSCN7593.JPG DSCN7594.JPG DSCN7596.JPG DSCN7597.JPG DSCN7598.JPG DSCN7599.JPG
Reactions: jmclaugh and zedric
zedric
Aug 8, 2012
1,841
354
Very nice. I assume the pendulum is a properly compensated one, not just for show
rstl99
Oct 31, 2015
1,174
292
Ontario, Canada
Chris,
Lovely clock by the firm of one of the French masters from the second part of the 18th century.
Jean-Antoine Lépine experimented with a lot of things during his horological career, especially once he took over the business from his father-in-law André-Charles Caron (you can see the articles I wrote for NAWCC on my website below). Certainly in watch design but also in clocks, Jean-Antoine kept trying different ideas, such as the rather interesting way he used the combination of roman and arabic numbers for the hours in a dial such as is on your clock. Almost too clever perhaps, and it obviously didn't catch on with other horologists, but it certainly identified a clock by him, if his name on the dial wasn't enough.
For fun, I put a picture of your Lépine clock (ca. late 1780's?) with one I myself recently acquired by Cronier l'Ainé (ca. 1810). Both feature very similar wood veneer case with four pillars, and a "Berthoud-style" pendulum. I read somewhere that some French clocks from that era, because of a war with the English that was going on, resorted to the use of more domestic woods, because of lack of supply of mahogany and other tropical woods normally coming from England. And also using wood because of a lack of brass, again related to the war apparently.
Anyway, they make an attractive pair side by side.
Robert
171,028
1,493,233
50,083
3号缐
2,967
