Unusual Banking 1828
Discussion in 'European & Other Pocket Watches' started by John Pavlik, Sep 15, 2020 at 11:30 PM.
  1. John Pavlik
    John Pavlik Registered User
    Dec 30, 2001
    2,168
    315
    Green Bay, Wi
    Has anyone seen a lever banking set up like this ? A square “pin” is dropped thru the top plate and the
    lever End has a square shape larger than the pin.. Appears there would not be adjustments to the banking unless you would remove material from the inside of the lever square.. Watch is circa 1828 with a Thomas Savage on the movement ... Appears to have a standard table roller.. but I have not removed the balance to Get a good look..The curvey piece that looks like an extension of the square pin is behind the square banking pin is actually the stop works... it stops the lever ..
    B39EC636-520D-47B4-98C5-061322824A6E.jpeg 277BBEDF-9AAE-4CDF-A382-325A8ABABCBB.jpeg 787AFB8A-A157-4E74-9FE1-00F4D433DD33.jpeg
    Dr. Jon likes this.
  2. Jerry Treiman
    Jerry Treiman Registered User
    Aug 25, 2000
    6,346
    1,763
    Geologist - California Geological Survey
    Los Angeles, CA
    It is hard for me to picture this from the images, but the description sounds like single-pin banking as on this John Cragg movement of mine -
    Dr. Jon likes this.
  3. gmorse
    gmorse Registered User
    11,587
    1,729
    Retired from Xerox
    Hi John,
    I haven't seen single pin banking implemented in precisely this way, but yours is essentially the same as Jerry's example. novicetimekeeper has another with a similar arrangement.
  4. Allan C. Purcell
    Feb 9, 2013
    2,486
    889
    retired
    Germany
    There are many variants of this banking, though I have to say this is the first with a squared pin. Many of these escapements can be seen in the thread "Early Single Table Roller escapements.
    Allan
  5. novicetimekeeper
    Jul 26, 2015
    10,090
    681
    Dorset
    Mine is like Jerry's, a lever with a hole in the end and a single banking pin. Alexander Purvis, 4 Audley St, Grosvenor Square, 1833. It says patent on the dial but no idea what that refers to. Graham has some excellent pic of it from when he serviced it.
  6. gmorse
    11,587
    1,729
    Retired from Xerox
    Hi Nick,
    This was taken prior to cleaning.
