Unknown movement - Repeater?
Discussion in 'European & Other Pocket Watches' started by SCinBZ, May 18, 2019.
  1. SCinBZ
    SCinBZ Registered User
    Mar 14, 2019
    20
    Does anyone recognize this movement? I've never seen the thing in the upper-right, although I'm reasonably new. There also appears to be a hammer and a "bell" strip. Any help is appreciated.
    MarvinM
  2. SCinBZ
    Mar 14, 2019
    20
    There seems to be the word Huguenin engraved in the engraved silver and enamel case, but no there markings.
  3. jess tauber
    jess tauber Registered User
    Dec 24, 2017
    136
    32
    This is definitely a later model repeater movement. Earlier movements didn't have the vibrating balls feature, just hammers that hit a gong wire that wrapped around the rim of the movement.
    Jess Tauber
  4. gmorse
    gmorse Registered User
    10,830
    1,358
    Retired from Xerox
    Hi MarvinM,
    Those 'vibrating balls' are the centrifugal governor which controls the speed of striking and are indeed a later method of achieving this. Earlier movements used a small verge and crown wheel escapement, (rather like an alarm), or a blind pinion at the end of the striking train whose depth with the previous wheel could be adjusted to alter the degree of friction.
    Keith R... likes this.
  5. dshumans
    dshumans Registered User
    Sep 17, 2009
    413
    44
    Yes, that's a centrifugal speed governor for the repeater. If you look closely, there are 2 hammers, not one, and 2 gong rods. That is so it can chime the hours and quarter hours using 2 tones. There should be a push button or slide to activate the repeater to chime the time. It may even be the crown which can be pushed down, as the plate layout is similar to a "trip repeater". It won't chime well now as there is a missing screw for the gong block that holds the gongs, and may have other issues.
    Doug
