Greetings all. The so far unidentified 6 3/4 ligne movement that I inquired about in the "Wrist Watches" section is running very fast. I demagnetized it, as it did show magnetism being an issue, but it isn't making up for gained time, so to speak. The movement seems to have two movable parts on the balance cock. One contains the stud. The other had the regulator pin/boot combo. It seems that I have seen this before on an electronic ESA 915* model, but don't recall what I did with it to regulate the rate.
Is the arm holding the stud for adjusting beat error and the one with the pin/boot for adjusting rate? Maybe this is obvious, but I'm a bit thick. Thanks for any help. I'll attach the image that shows the top of the balance cock. Cheers.
