Ultrasonic Cleaning Solution
Discussion in 'Clock Repair' started by David Walker, Dec 26, 2019.
  1. David Walker
    David Walker New Member
    Dec 18, 2018
    Hello. Best of the season to you.
    My question is how often should I replace the cleaning solution in my cleaner or how do I tell it’s time to replace it?
    Many thanks in advance,
    David
  2. dickstorer
    dickstorer Registered User
    Oct 19, 2010
    763
    32
    Retired Military
    Hampton, Georgia
    You will get many different answers. I leave mine as long as it still gets things clean and it is my own mixture.
    David Walker likes this.
  3. R. Croswell
    R. Croswell Registered User
    10,340
    872
    I use Deox-007 and also generally use it as long as it works. Once in a while I pour it through coffee filters to remove any particulate matter. I'll probably dump it the first of the year because it has gotten so dark I can't see parts in it any longer. I use a small cleaner so it isn't too expensive to change the solution more often.
    David Walker and disciple_dan like this.
  4. Willie X
    Willie X Registered User
    12,774
    985
    What DS said.
    If you don't heat the solution and don't run the US for so long, it will last a lot longer.
  5. wow
    wow Registered User
    Jun 24, 2008
    4,150
    294
    Retired Music Minister
    Pineville, La. (central La.)
    Yes. Heat cleans very dirty/oily parts faster but the solution becomes contaminated faster. I find that cleaning parts first by spraying with naphtha and a bristle paint brush, gets the gook off. Then I run them in the US in cold solution.
