ultrasonic cleaner
ilchick47
Jan 5, 2021
30
74
I am looking to purchase my first ultrasonic cleaner any suggestions or guidance in this area
Vernon
Dec 9, 2006
993
123
For clocks, the little 2.5 liter from Harbor Freight served me well until I upgraded to a 10 liter Chinese unit available on ebay (or was it Amizon) at about $130. Both have heat and timed cleaning. Size will depend on what you want it for.
Kevin W.
23,150
556
Bought mine off amazon, its not a common name, works great very happy with it, not expensive either.
Altashot
Oct 12, 2017
315
93
45
I’m not going to recommend any particular Brand, but I suggest that you get a bigger one. Bigger than what you think you might need.
It’s a common mistake to buy too small and regret it later.
M.
Reactions: lpbp
46,719
1,913
I agree. I ended up with three of them before I finally got one big enough to actually be a help and not a hindrance in the workshop. I wouldn't suggest anything smaller than one gallon. Mine is three gallons and still barely big enough to clean everything at once on a big movement. If you have to run two or three separate cycles to clean a movement, you might as well do it by hand. There is no time savings there.
Reactions: lpbp
46,719
1,913
That's roughly 1.5 gallons. If it were more square shaped it would allow a big plate to lay down, but if it's high enough to cover a big plate with solution it should work fine.
Reactions: Kevin W.
Kevin W.
23,150
556
There is not a huge difference in price , to go to next size larger. For me i put the big plates on their sides. As i dont work on many clocks like gf clocks and such.
Reactions: ilchick47
ilchick47
Jan 5, 2021
30
74
I found a 15L that looks interesting researching reviews ect looks like it might be ok also ordered the fluid. Have a mechanism that has issues will use as trial
Reactions: Kevin W.
46,719
1,913
That one should serve you well. Remember that cleaning is only part of a complete service ;)
Kevin W.
23,150
556
Mine is a 5 litre if i remember correctly, should be ok for cuckoo movements.
bikerclockguy
Jul 22, 2017
752
77
I have a Harbor Freight ultrasonic, and I honestly can’t tell that it does much of anything. I wash all my parts in the sink with a dish sponge and Dawn or Palmolive first, then run them through the US for 2 or 3 cycles with heat, thinking this will probably clean down inside the lanterns and cracks and crevices I can’t reach, but there’s rarely much of a noticeable difference in the parts or the color of the water when I’m finished
Kevin W.
23,150
556
Mine does a really good job on clock parts, it saves me so much time. Great investment for me.
FDelGreco
NAWCC Star Fellow
NAWCC Diamond Member
Aug 28, 2000
2,281
190
Novelty, OH
I think you get what you pay for. I've got two units, a six quart and an 11 quart. Both are made by L&R. They cost a LOT more than the Harbor Freight units but are great at cleaning.
Frank
bikerclockguy
Jul 22, 2017
752
77
Frank
I had wondered if maybe that were the issue, but there are lots of people on here that swear by the Harbor Freight units. When I first started using it, I ran the parts through the US first, and in that case the water was dirty and there was a noticeable difference in the parts. I noticed it didn’t get the really grimy parts(like spring grease deposits around the winding arbors)very clean though, so that’s when I started hand washing the parts first, and then the difference after the US cleaning seemed almost negligible.
JeffG
Jul 8, 2020
81
24
St. Croix, U.S.V.I.
I think it might be a matter of not knowing how good an US can be.
I've had the cheaper HF type and thought it was great until a physician friend gave me his high-dollar model when he upgraded. There's a big difference. Reaching a couple of fingers in to rearrange things while it's running really hurts!
T.Cu
Sep 26, 2020
146
25
I bought a six liter one, a Chinese model from ebay, for a little over a hundred bucks if I remember right. And it works but is still a little small to fully immerse stuff, so I have to do one side at a time, sort of switch it around every minute or so. Part of that is trying not to make a huge mess by filling it completely. Because I have been using the ammoniated stuff from Ronell.
That is very interesting about sticking your hand in there and having it hurt! I always use nitrile gloves but I sure never noticed that.
JeffG
Jul 8, 2020
81
24
St. Croix, U.S.V.I.
Yeah man, like little zaps within my knuckles. I don't recommend trying it out.
Reactions: T.Cu
46,719
1,913
You can test your US with a piece of tinfoil. If it doesn't punch little holes in it, it's not going to clean very well.
Kevin W.
23,150
556
I put foil in my chinese made ultrasonic, this is after 15 minutes. I would say my us passed the test.
Reactions: Rockin Ronnie
T.Cu
Sep 26, 2020
146
25
That surprises me a little, that it does that much damage. I don't leave anything in for that long though, but still.. I will test it next time I put something in there. Sheesh.
Reactions: Kevin W.
Kevin W.
23,150
556
Well something fragile like a hair spring, its not recomended to clean them in a us, some will and have disputed this, to each his own on this point.
Reactions: T.Cu
46,719
1,913
Yes, a hairspring will take the same beating if left too long. Keep in mind that tinfoil is soft and shows the force of the ultrasonic cleaning pretty clearly, and quickly.
166,251
1,448,537
86,766
Dmvalente
2,910
