U.S. Watch Co. (Waltham) replacement hairspring
Discussion in 'Watch Repair' started by RyanM, Jun 3, 2019.
  1. RyanM
    RyanM Registered User
    Feb 27, 2019
    73
    37
    I have a size 0 Unites States Watch Co. of Waltham that came to me with a pretty terribly bent (sharp bends in multiple locations) hairspring and am having trouble discerning what kind of replacement hairspring to get for it. Ideally I'd like to learn how to find the information myself rather than have to ask around every time I have a similar issue. I know there is a materials book for the more common manufacturers, and my copy is being delivered, but I do not believe this manufacturer is included.
    Any information would be appreciated, thanks!
  2. Albert Antonelli
    Albert Antonelli Registered User
    Jan 8, 2011
    216
    Ryan, is it possible that u can straighten the hairspring I know this is a tricky thing to do but, to get a new or in good shape hairspring to fit your balance, I’m sure u know if u find a hairspring it still needs to be vibrated to your balance wheel. My two cents worth good luck.
  3. Dave Coatsworth
    Dave Coatsworth Forums Administrator
    NAWCC Business Sponsor
    Feb 11, 2005
    6,575
    1,431
    Watch Parts Dealer
    Camarillo, CA
    If he gets a correct factory hairspring that is colleted and studded, it will have already been vibrated.
  4. RyanM
    Feb 27, 2019
    73
    37
    I could try, and probably will, but I'll also have a backup plan just in case. I've seen people suggest using sewing machine needles with the tip cut or filed off so that the slot is open to work with hairsprings. It will at least be good practice. It is in pretty rough shape, though.
    kevin h likes this.
  5. Tim Fitzgerald
    Tim Fitzgerald Registered User
    Jan 2, 2016
    690
    443
    Artist
    Oak island North Carolina
    It's a very frustrating job, straightening a hair spring. But it is very rewarding when you get it right. I have never heard of the sewing needle tool. Thanks
    RyanM and kevin h like this.
  6. Skutt50
    Skutt50 Registered User
    Mar 14, 2008
    3,477
    107
    Gothenburg
    Could you post a picture? It is much easier to discuss things when you see what they look like.
    It is preeey straight forward. Find the smallest sewing needle you can and file off the tip of the eye. You then have a small fork that fits nicely over the hairspring. Fit it to a small handle and you have a useful tool for manipulating bent hairsprings. I used them a lot in the past but have more recently moved back to tweezers. I still use the needle tools specially if one needs to make a "sharp" bend type adjustment.
    RyanM and Tim Fitzgerald like this.
  7. Tim Fitzgerald
    Jan 2, 2016
    690
    443
    Artist
    RyanM likes this.
  8. D.th.munroe
    D.th.munroe Registered User
    Feb 15, 2018
    366
    130
    Full time clock and watchmaker
    BC Canada
    I think in deCarle's Practical Watch Repairing, he has a sewing needle tool but I think he only uses it to break of the center or outer end of new springs. Also sewing machine needles are handy for this and some other things.
    Dan
    RyanM likes this.
  9. Skutt50
    Mar 14, 2008
    3,477
    107
    Gothenburg
    I never tried that. My problem when searching for needels to use was to find needles with small enough eyes. Most needles I found were too big. Last time i found a set of needles where only the two smalest were what I was looking for.
    RyanM likes this.
  10. RyanM
    Feb 27, 2019
    73
    37
    Here is a pic of the hairspring.
    kevin h likes this.
  11. kevin h
    kevin h Registered User
    Apr 9, 2015
    408
    151
    cambridge md
    ohhh dear .....
    RyanM likes this.
  12. Tim Fitzgerald
    Jan 2, 2016
    690
    443
    Artist
    My that is a mess. Good luck.
    kevin h likes this.
  13. RyanM
    Feb 27, 2019
    73
    37
    And here is a pic of that watch's hairspring now.
    Thank you @Dave Coatsworth for getting me the replacement.
    Rick Hufnagel likes this.
  14. Skutt50
    Mar 14, 2008
    3,477
    107
    Gothenburg
    I fully understand why you wanted to replace it. The old hairspring can probably be saved and made into a working condition but with all those kinks and bends it will not be unvisable and the effort is way too time consuming.
    Congratulations on finding a replacement!
    RyanM likes this.
  15. praezis
    praezis Registered User
    Feb 11, 2008
    430
    19
    Germany
    Is your watch running again and how?
    Usually a marriage of balance wheel and hairspring of same calibre but from different sources does not work. I wonder if this is different with American PW.
    Frank
  16. Tim Fitzgerald
    Jan 2, 2016
    690
    443
    Artist
    Glad you got your spring. Dave has saved my bacon on many occasions!
  17. RyanM
    Feb 27, 2019
    73
    37
    I have a few other watches to get to before this one, I'd just put the hairspring on to test, but while installing a bench lamp, a rain of dust fell directly on the movement, so I have to clean it again. I'll get to it this weekend and let people know how it goes.
