Clock$44ga
- Jul 31, 2022
- 14
- 1
- 3
- 59
- Country
Hi,
A friend of mine asked me to look at a clock that has been in his family for many years. At some point, somebody removed the mechanical movement and replaced it with a battery movement. The person also glued a piece of paper over the winding hole. (WOW)!! Does anyone have any advice on how to clean the face, the face is painted on metal.
I told him that I would try to locate an Ansonia mechanical movement to bring it back as close to original as I can. As you can see by the pictures, the distance between the winding arbor and the center arbor is 1 3/8". All of the movements that I have researched have been 1 5/8" or more. Should the measurements be center to center? Also the screw hole that holds the movement in the case are 2 at the top and 2 at the bottom. Most of the time only Ansonia movements have 1 screw hole toward the side. Any information would be greatly appreciated.
Thanks in advance,
Ronnie
Thanks in advance,
Ronnie
