Triple chain fusee. What style of clock or type of case?
Discussion in 'General Clock Discussions' started by D.th.munroe, Feb 28, 2019.
  1. D.th.munroe
    D.th.munroe Registered User
    Feb 15, 2018
    464
    167
    Full time clock and watchmaker
    BC Canada
    Hi all,
    I have this triple fusee with Westminster chime on gongs. There is pics of it already on my thread in the new acquisitions, but I found a pendulum with the same lot number sticker.
    I'm having a hard time finding anything similar to recreate a case.
    The combination of the movement and the dial, which kind of looks like a lantern clock dial, is odd to me. So I'm just wondering if anyone has seen one like it or has any ideas what would suit?
    I have the movement cleaned and 90% repaired now so I'll show pictures when im done.
    I'm also unsure what I should do with the dial? I dont know if it was originally silvered in the center and brass chapter ring, seems to be no evidence of silvering on the chapter ring but just seems backwards.
    Dan.
  2. Chris Radano
    Chris Radano Registered User
    Feb 18, 2004
    3,662
    208
    Pennsylvania
  3. brian fisher
    brian fisher Registered User
    Jan 20, 2017
    1,468
    326
    houston, tx
    do you really think this movement is that new chris? i would guess its about 100+ years older than that.
    and yes, i agree the silvering seems backwards on the dial....
  4. Uhralt
    Uhralt Registered User
    4,804
    560
    I suspect both the chapter ring and the center where originally silvered. Probably the chapter ring has been cleaned and polished multiple times over the years but the center has been left alone due to the engravings.
  5. D.th.munroe
    Feb 15, 2018
    464
    167
    BC Canada
    Thanks guys.
    That is a beautiful clock Chris. I really dont know the age of it. When I first saw it and was in a rush loading stuff it made me think of W&H and maybe later 19th because its size, the dial is 12". I really dont get to see alot of bracket clocks around here though. The only markings I found are the G.B. on the gongs. It's gonna be fun gettin the rust off these gongs but luckily its the only rust on the whole thing.
    Dan.
  6. Chris Radano
    Feb 18, 2004
    3,662
    208
    Pennsylvania
    I would guess Elliott. Yes that's a large dial, most bracket clocks have 8" dials. I wish I could have seen the original case, because the dial and hands look "retro". A regency style case would accommodate a 12" dial better than a bell top (which usually had a break arch dial). A basket top case may work as the proportions are smaller, but they usually had a square dial. Congrats on your triple fusee!
  7. D.th.munroe
    Feb 15, 2018
    464
    167
    BC Canada
    Thanks Chris.
    I wish I could've seen the case as well, it is a bit odd. I'm hoping there may still be a clue in some of the other boxes I haven't gone all the way through, that pendulum was nowhere near the clock, the only clue that it goes with it (if it does) was the stickers with the same numbers. Lol
    Dan.
  8. zedric
    zedric Registered User
    Aug 8, 2012
    1,125
    152
  9. jmclaugh
    jmclaugh Registered User
    Jun 1, 2006
    4,674
    121
    Devon
    That's a big dial for a bracket or boardroom clock, anyway the movement doesn't correspond to any by FW Elliott or JJ Elliott shown in Clockmaking in England & Wales in The Twentieth Century. Is that a rise and fall adjustment above 60 on the dial?
    If that's a circa 1890 Sheration boardroom clock it can't be by FW Elliott as the company wasn't formed until1923.
  10. Chris Radano
    Feb 18, 2004
    3,662
    208
    Pennsylvania
    Thwaites and Reed? As stated, probably plays Westminster chimes by the look of the pins on the cylinder. If so, then 3rd quarter 19th c. - on.
  11. D.th.munroe
    Feb 15, 2018
    464
    167
    BC Canada
    Yes it's a rise and fall adjustment above the 60.
    Also yes for sure Westminster chimes. Heres a couple more pictures of it I took before.
    Dan
  12. D.th.munroe
    Feb 15, 2018
    464
    167
    BC Canada
    Thwaites and reed could be possibe. After looking there is a couple similarities in work, but really after I found no marks I figured it would be hard to attribute it to anyone for sure. Although If you search google for "Thwaites and Reed balloon clock" the first hit for me is one with a 12" two piece dial. Its only double fusee and the dial is different but close. It is for sale so cant post it here.
    Dan.
  13. jmclaugh
    Jun 1, 2006
    4,674
    121
    Devon
    Thwaites & Reed movements are usually marked, often this is T&R stamped on the front plate. My opinion is this isn't one of theirs.
  14. D.th.munroe
    Feb 15, 2018
    464
    167
    BC Canada
    Ahh ok. Thank you.
    So far the only triple fusee's I've had the pleasure of working on are 2 Winterhalder and Hofmeier's and a tiny bit older English square dial one.
    I do also have the older one I posted with this one in the new acquisitions but I put it away for now. Even though I trust my skills, I am a bit of a perfectionist and it's something I would like done as properly or accurate as possible. So really only going on what I can find on google and in my books.
    Dan
