Electric WW Trimmer for Bulova Quartz
whizzer
Mar 18, 2008
197
I would like to replace the trimmer on a couple of Bulova 242 series circuits but can see nothing on the existing trimmers to indicate value, make, model, etc.
The circuits run and the accuset function works but the circuits lose 20 + seconds a day. The trimmers show signs of very rough treatment (distorted screw slots) and were probably damaged by such.
Watches these circuits were in run within specs with another circuit so it's not the motor or mechanical parts.
How do I find the proper trimmers ?
Thanks for any guidance.
Skutt50
Mar 14, 2008
4,486
608
Gothenburg
Do you know if it is a resistance or capacitor trimmer?
If it is a resistor type the resistance would be easy to measure on one of the working parts..... You do however need a multimeter.
whizzer
Mar 18, 2008
197
Since there is no continuity across the leads of a good one I assume it's a capacity trimmer.
Skutt50
Mar 14, 2008
4,486
608
Gothenburg
If it is a capacitor it will be a bit more tricky to measure it but if you can find someone with a capacitor tester they should be able to help out!
I have an old (Japanese) multimeter from the 70-ies which measures capacitance (if I only could find a proper 10v battery......) so they do exist even if not just any multimeter will do the trick......
flynwill
Feb 1, 2007
1,029
10
Rolling Hills Estates, CA
flynwill.com
You will have a hard time measuring the existing with any accuracy. These trimmers are typically in the 20-60 pF (that's pico-Farads) range. I don't know if you can get suitable trimmers from the electronics distributors like Digikey, but that's where I would probably start. Look for something that will mechanically fit and buy several different ranges and give them a try.
dAz57
Dec 7, 2011
2,013
37
sydney Australia
these capacitors have ceramic plates, very light pressure is used when adjusting them, any heavy handed treatment will result in cracking the ceramic plate and making it useless.
whizzer
Mar 18, 2008
197
Thanks for the information.
What I learned in the Army Communication School in 1952 is a bit outdated.
The trimmers in question seem to be of different types. One has thicker plates that look ceramic and the other has copper plates. I'll have to remove a circuit from an assembled watch to see which should be correct.
When time permits I'll check with a local electronic repair company as a possible source.
Staff online
181,563
1,584,193
54,865
ClockGrandma
3,137
Pocket Watch Regulator by Kent
Top Bottom
