Trifix mainsprings
Discussion in 'Clock Repair' started by S1ider, Jul 17, 2017.
  1. S1ider
    S1ider Registered User
    May 10, 2012
    427
    Peterborough UK
    Can somebody confirm that Trifix mainsprings come pre-lubricated. According to Cousins they do. I have always brought my springs from them, but have always cleaned and lubricated before installing. If they come lubricated like Cousins say they do then it will be a bonus. I thought it was an inhibitor on them to prevent rust, but surely Cousins should know ? Shouldn't they ?
  2. shutterbug
    shutterbug Super Moderator
    34,643
    44
    They might lube them there, but typically the goop on the spring is just a rust inhibitor, and makes a poor lubricant.
  3. shimmystep
    shimmystep Registered User
    Mar 5, 2012
    3,676
    Cambridge, UK
    Tri-fix springs from cousins, or from anyone, always need a clean and lube before installing. Not only do I think that what they are covered in is an inhibitor, the annealed ends of the springs are covered in carbon scale. This will only serve to crack and distribute in the spring and inhibit its intended action, i.e. it will inhibit the the coils sliding over each other.
  4. S1ider
    May 10, 2012
    427
    Peterborough UK
    Thanks guys. I will just continue as i was then. :coolsign:
  5. AJSBSA
    AJSBSA Registered User
    Nov 24, 2009
    483
    Clockmaker
    Cheshire, UK
    I have been using Trifix springs for the last 7 to 8 years which must amount to thousands by now, this what I currently do
    Remove scale from both ends use paper towel to clean off the rust inhibitor, grease then use Hermle barrel centre and my home made spring winder
    [​IMG][​IMG][​IMG][​IMG][​IMG]
  6. S1ider
    May 10, 2012
    427
    Peterborough UK
    Thanks for the pics Stephen. Good info. Obviously you find that Horoglide works well. Do you keep topping it up or do you buy a new syringe full each time ? I have never used that before. Or is that not whats in it ?
  7. AJSBSA
    Nov 24, 2009
    483
    Clockmaker
    Cheshire, UK
    Hi I have been using M&P mainspring grease for years with no problems, Horoglide is a new product from M&P which comes in its own syringe tube I am very happy with it but what ever you do, do not buy their Graphite grease it is truly awful to apply you will spend a huge amount of time cleaning up after using it.
  8. S1ider
    May 10, 2012
    427
    Peterborough UK
    Thanks. I shall have a look at Horoglide.
Similar Threads - Trifix mainsprings Forum Date
Strike and time mainsprings switched? Clock Repair Thursday at 9:37 PM
Le castel, St-Aubin movement and Mainsprings Clock Repair Aug 23, 2017
Seth Thomas Mainsprings Stick Clock Repair Aug 2, 2017
Can Mainsprings Be Rejuvenated? Clock Repair Jul 28, 2017
Trifix Clock Mainsprings Clock Repair Apr 5, 2015
