They will have to be removed and carried separately. I usually roll them up in builder's paper (sometimes called red rosin paper), up to 3 in each bundle. Cut the paper about 16" longer than the longest tube, roll that tube up about 2 turns, lay the second tube beside the already wrapped one, make one more loose wrap around both tubes and then lay on the third tube and wrap until the 36" width of the paper is used. Fold back the paper at the ends and secure with tape.
For the weights, first crank the weights up with a block of styrofoam above each pulley. Slightly crush the styrofoam into the pulley before removing the weights. You can use a 4" length of pool noodle for this (hole going vertically). Wrap each weight in a towel and carry each one separately.
Lift the pendulum up about
1/2" and carefully unhook the suspension spring assembly. Carry the pendulum carefully (no wrapping) just lay it flat on a towel in a safe place, where it can't slide around and damage the suspension spring.
Hope this helps,
