tooth decay :-(
Discussion in 'Watch Repair' started by Britannicus, Jan 26, 2019.
  1. Britannicus
    Britannicus Registered User
    Apr 26, 2016
    283
    13
    IT consultant
    Derby UK
    Hi there - I have a nice functioning Waltham which struggled to wind. So I got the back off to see that the problem seems to lie with the ratchet wheel missing a tooth - is there any way I can fix this - or is it just a question of looking for a suitable "spare or repair" wheel - pocket watch DB says it's a model 1888 made in 1894 - scale is in mm
  2. Dave Coatsworth
    Dave Coatsworth Forums Administrator
    NAWCC Business Sponsor
    Feb 11, 2005
    6,583
    1,446
    Watch Parts Dealer
    Camarillo, CA
    Hi Britannicus,
    Since this is more of a repair question, I'm going to move it to Watch Repair.
  3. richiec
    richiec Registered User
    Feb 24, 2007
    6,507
    389
    automotive warranty inspector
    Brick, Ocean, NJ
    I would look for another, I have a bunch of parts that I can look through to see if I have anything that matches.
  4. karlmansson
    karlmansson Registered User
    Apr 20, 2013
    2,585
    111
    Doctor
    Linköping, Sweden
    Is it a steel or a brass wheel? If it’s brass (which it probably isn’t) it can be salvaged by making a dove tail recess where the root of the broken tooth is. You can then insert a matching brass piece with enough protruding for you to be able to form a new tooth with very fine files or, if you have it, a form tool on a milling machine. It’s very delicate work and if you haven’t done it on a clock before, I would hesitate to do it.
    For clocks you can add a little bit of soft solder to keep the piece in there axially. For a watch I think the best would be to peen the inlay piece stuck. I have never done it on a watch though, just know that soft solder has no business in watches.
    Still, if you get the chance to do it on a clock I can recommend it. Very satisfying!
    Best regards
    Karl
  5. Chris Radek
    Chris Radek Registered User
    Apr 13, 2014
    516
    164
    Watchmaker (now accepting new customers)
    Lincoln, NE, USA
    Be aware this is probably a result, not the cause, of the hard winding. If you put in a new wheel without a correct repair and service you might just break the second one. Plain lack of service can sure do this, but so can various kinds of wear.
  6. gmorse
    gmorse Registered User
    10,827
    1,357
    Retired from Xerox
    Hi Britannicus,
    Whilst Karl's suggestion is technically possible, on a steel wheel like this you'd really need to use a hard solder to make it secure, but there's no way you could do that without ruining the cosmetic appearance of a damaskeened wheel like this. I think peening it in wouldn't work here because these wheels are pretty hard, and it would still leave ugly marks however carefully it was done.
    karlmansson likes this.
  7. pocketsrforwatches
    pocketsrforwatches Registered User
    Feb 13, 2008
    265
    Retired from IBM, now a Watchmaker
    Ticonderoga, NY
    I think I have what you need. PM your email and I'll send you a picture. I'll mail it to you N/C if you can use it.
    Roger
  8. karlmansson
    Apr 20, 2013
    2,585
    111
    Doctor
    Linköping, Sweden
    I agree Graham! Note that I wrote that if it is NOT steel. Slim chance for a ratchet wheel but it was hard to tell from the picture.
  9. Ticktinker
    Ticktinker Registered User
    Jul 7, 2015
    1,067
    Construction Inspector
    Houston Texas
    Not sure if it would interchange but I have a donor model 1894.
    Perhaps if you posted an outside diameter... I could check against what I have.
