• Upcoming updates
Tool to measure how powerful a movement is (torque)?
Aloha
Feb 20, 2021
35
33
Is there a tool clockmakers use to measure the torque of a movement? For example, say I wanted to add a complication to a movement could I measure how much torque that isolated complication requires? In the same line of thought, is there a tool that could measure how much torque a clock mechanism has to measure how strong a clock mechanism is relative to another one?
R. Croswell
12,290
2,148
www.greenfieldclockshop.com
I use a torque screwdriver fitted with a chuck (clock key) to fit the winding arbor. You can apply the torque you need to start things moving as well as measure the torque required to release the click, which is the torque the spring is imparting to that arbor. You might try www.mcmaster.com or other machine tool suppliers.
Reactions: Aloha
Aloha
Feb 20, 2021
35
33
Thanks, what a simple solution.
179,118
1,571,180
54,072
Anthracite
909
3,088
Swiss Fake by Kent
