Hi all,
Want some G. Boley / BTM "Geneva" style tailstock parts? These are from an old D-bed or triangle.
I'm
not selling anything, just giving stuff away. They're not branded or perfect, but useful. If there's no interest, then I'm scrapping them: It's a large, cast iron, nickel plated double pulley for a 6.6mm tailstock (or turns) fits on your spindle shaft. These were for turning larger work between centers. It's only the pulley and you'll have to make the arm, etc. The taper
does not fit the 7mm W-J / Lorch / Generics, or I would keep it
It fits the G. Boley. Also have a 6.6mm shaft sized jacot drum (slots are 2,5-11). I would rub it with some diamond paste, then use it, but it doesn't fit my stuff. Both are probably 100 years old...
All I am asking for is postage via PP. PM me (do not reply here) if you can use this stuff and cover the postage. I'm in the EU, so that's the drawback.
