Too fast or too slow
Discussion in '400-Day & Atmos' started by Dells, Nov 27, 2019.
  1. Dells
    Dells Registered User
    Oct 18, 2019
    177
    15
    Coach builder
    In the cotswolds UK
    Hi all
    I have a Gravolas and a Gustav Becker and both of them to slow with 0040 and pendulum wound all the way in and with 0045 to fast with pendulum wound all the way out, has anyone got any suggestions.
    Many thanks in advance Dell
  2. whatgoesaround
    whatgoesaround Registered User
    Jan 22, 2008
    446
    22
    science teacher
    south carolina
    Probably the best bet would be to thin the larger spring in small increments.
    Dells likes this.
  3. Wayne A
    Wayne A Registered User
    Sep 24, 2019
    339
    47
    Retired, process controll systems
    Sounds like you need a suspension spring size that falls somewhere between those two. One option is to put in the .0045 and thin/test the spring until you get the pendulum into range. You can make a little sandpaper tool out of wood like popsicle sticks so you can sand both sides of the spring at the same time. Make a few passes with 600-800 grit and test.
    Dells likes this.
  4. Dells
    Oct 18, 2019
    177
    15
    Coach builder
    In the cotswolds UK
    Thanks for reply’s
    Do I sand the edges or the flat ?
  5. Kevin W.
    Kevin W. Registered User
    22,452
    368
    You are sanding the flat of it. Check often as mentioned, it goes quicker than you think.
    Dells likes this.
  6. KurtinSA
    KurtinSA Registered User
    Nov 24, 2014
    3,657
    142
    Aerospace Engineer (Ret.)
    San Antonio, TX
    Also, the portion of the spring between the fork and top block is the most important. I usually leave the bottom block on and sand the spring from there to the top and off the end.
    I thought we had an interesting discussion in this thread about finding the right spring. I don't think I can measure the thickness accurately as it changes, so the idea of using a "spin test" as you thin the spring to size. First try a spin to see what the timing is then rehang the pendulum and spring to see how the timing changes as it thins. There is an issue with spring length which is what I was sort of discussing in the thread, but Eric had a good suggestion about putting the top block in place at the proper length and see what the timing is.
    Choosing the right suspension spring
    Kurt
  7. etmb61
    etmb61 Registered User
    Oct 25, 2010
    2,481
    167
    Retired Avionics Technician
    Mascoutah, IL
    Most of the old disc pendulums (if not all) require a non-standard spring size. People have done some really strange (and scary) things to them over the years trying get them to keep time with the springs they had available. Thinning a modern spring is not that difficult or critical, though some of the instructions I've seen try to make it seem like it is.
    Eric
  8. Dells
    Oct 18, 2019
    177
    15
    Coach builder
    In the cotswolds UK
    Thanks Kurt & Eric
    I did read the post you linked to I also understand that making the spring longer or shorter changes things but I think I will stick with thinning and see what I can do, I tried changing length and it looks all wrong with the pendulum to high ( I used an old spring to save wasting a new one.
    Dell
  9. KurtinSA
    Nov 24, 2014
    3,657
    142
    San Antonio, TX
    My point was that I have an aversion to cutting a spring before I've determine that it is going to work. Even though the guide might suggest a spring size, sometimes due to differences in the pendulum, the time can't be regulated. So there are ways to test the spring with the pendulum to confirm it is correct. Then you can cut with confidence.
    Kurt
  10. Dells
    Oct 18, 2019
    177
    15
    Coach builder
    In the cotswolds UK
    Well have sanded 0045 down 10 strokes with 400 & 10 strokes with 1200 set pendulum adjuster to approximately the middle and now Gravolas is running about 20 seconds slow per hour so that should be easy to alter on pendulum adjuster.
    Now to do Gustav Becker.
    Thanks everyone
    Dell
    Wayne A likes this.
