Tobias with Breuget Shock absorber like an Incabloc and a Compensation Curb.
Discussion in 'European & Other Pocket Watches' started by Omexa, Jun 19, 2017.
  1. Omexa
    Omexa Registered User
    Feb 28, 2010
    3,446
    Hi, inside a truly Horrific Case with a "Patent" sic movement securing device, this Parachute movement needed rescuing. It looks like a Classy movement, the Dial has "Tobias" on it and I wonder if it is a Swiss movement sold by Tobias as they got nearer to closing? It has a rather elaborate Ratchet assembly on the Winder and the Plate under the Bridges has a nice mottled appearance. It has a very long Lever and a Strange Balance with equidistance Balance Screws. I hope that the Breuget Shock absorber has done its job and the Balance Pivots are OK? Now ideas on who made it, approximate Date and when did M I Tobias close assuming that it came from their Shop? Regards Ray View attachment 347298 View attachment 347299
  2. Omexa
    Feb 28, 2010
    3,446
    #2 Omexa, Jun 19, 2017
    Hi, I just noticed something on the Winder bridge, what may be a Makers Logo? I will have to wait until I can remove it from the Case. Regards Ray View attachment 347331 .
  3. Omexa
    Feb 28, 2010
    3,446
    Hi, I just found this from eri231 "the parechute (shockproof) and the thermal compensation invented by Breguet are rarely used in Switzerland. In fact, this is a French Ebauches of Besancon area. a nearly identical is depicted in the book "La Montre Francais" of Chapiro." So it may be of French origin? Regards Ray
  4. Omexa
    Feb 28, 2010
    3,446
    Hi, it looks like I have some other ones buried somewhere. https://mb.nawcc.org/showthread.php?99828- Arnold-Adams-Co-London-Detached-Lever-13-Jewels-Parachute-and-Compensation &highlight=parachute+omexa Regards Ray
  5. Dr. Jon
    Dr. Jon Registered User
    Dec 14, 2001
    5,017
    15
    Aerospace Engineer
    New Hampshire
    #5 Dr. Jon, Jun 21, 2017
    Very interesting watch but I an suspicious that it is fake. Ofr openers iI am suspicious off all watches signed by this "maker". The photo is not enough to tell for sure but the compensator looks to be a simple piece of brass and not bimetallic and the parachute is very heavy. The bimetallic on the compensators is hard to see under the best of circumstances so the photo is not proof it's wrong.
    The parachute, o work ,it has to be delicate and resilient.This example looks too thick and clumsy to function. It may be thin but not in the direction of the photo. It looks crude to me, especially compared to others including your Arnold Adams.
    If this is a fake, it is the first counterfeit of these I have seen and I had no idea they did this (if infact they did).
    I
  6. Omexa
    Feb 28, 2010
    3,446
    #6 Omexa, Jun 21, 2017
    Hi Dr. Jon, it seems to me to be an awful lot of work to do to make a "Fake"? Just a plain Balance Cock assembly would be sufficient to make a saleable "Fake"
    Pocket Watch. It is interesting that all the photos from this seller have a red tinge on the shiny bits which do not make the movement look very nice. I am hoping that when I receive it my supposition that the Balance and other parts are nice and shiny are true. I will have a go with Photoshop to see if I can make the shiny bits a bit more attractive. I just thought that because it is in another Case it may not be the Original Dial. Regards Ray
  7. Omexa
    Feb 28, 2010
    3,446
  8. gmorse
    gmorse Registered User
    7,304
    26
    Retired from Xerox
    Hi Ray,
    Isn't "Arnold Adams" a fictitious name anyway?
  9. Omexa
    Feb 28, 2010
    3,446
    Hi Graham, from Les Harland: "Loomes Watchmakers and Clockmakers of the World only has one entry Adams Arnold and co London 19c."
  10. Benjamin E.
    Benjamin E. Registered User
    Sep 7, 2015
    7
    Both those parechutes are non-functional, it looks like. There's no split opposite the round kink; it's solid all the way through.
    Arnold Adams is a mix of the names of two well known London firms: Arnold and F.B. Adams. I don't believe there was any merger of the firms, just someone piggybacking off their success.
  11. Omexa
    Feb 28, 2010
    3,446
    #11 Omexa, Jun 21, 2017
    Hi Benjamin E., could you please show a photo of what you mean? I have found some others with a split and some without? Regards Ray
  12. Benjamin E.
    Sep 7, 2015
    7
    https://mb.nawcc.org/attachment.php?attachmentid=343435&d=1494544922
    It's right above the screw to the right of the balance jewel. It's what allows the parechute to flex and suspend the staff. Breguet's later watches had a different kind of elastic suspension. For a good illustration of this, see Habsburg's auction catalog and "Breguet: Art and Innovation in Watchmaking", the catalog of the Breguet exhibit at the San Fransisco Legion D'Honneur.
  13. Omexa
    Feb 28, 2010
    3,446
    Hi, I understand, but are there variations on a theme? Without the split it would work in one direction only (at right angles to the Balance Cock) and with the split it would work in two directions (at right angles to the Balance Cock and along the Balance Cock View attachment 347545 View attachment 347546 as well). Regards Ray
  14. gmorse
    7,304
    26
    Retired from Xerox
    Hi Benjamin,
    I think you're right, there was certainly no merger of these two companies; John Roger Arnold was in partnership with Edward John Dent between 1830 and 1840, and after Arnold's death in 1843 Charles Frodsham bought the name and stock in trade. No suggestion of Swiss manufactured movements! F.B. Adams made high quality watches and chronometers in Clerkenwell.
  15. Omexa
    Feb 28, 2010
    3,446
    There are so many "Arnold Adams", Pocket Watches around, in 100's if not 1000's surely the Swiss Company would have had a London office? Regards Ray
  16. gmorse
    7,304
    26
    Retired from Xerox
    Hi Ray,
    To quote a highly respected authority, (one D. Penney):
    "Swiss manufacturers spent much of the 18th and early nineteenth century making English-style watches, many of which were sold bearing fake 'London' names into various markets around the world. Liverpool looking watches, like this, were aimed at the American market where fake names such as 'Arnold' and 'Arnold Adams' were regularly used. This highly dubious practice, one that went on for the best part of two hundred years, is one that the Swiss try hard now to ignore - which may perhaps come as no surprise. That said, fake watches like this had a great effect on the business of watchmaking worldwide and every collection should have an example, but they should also be recognised for what they are - fakes!"
  17. Omexa
    Feb 28, 2010
    3,446
    Hi Graham, I think that you misunderstood me; I meant an office in London selling Fakes! Regards Ray
  18. Omexa
    Feb 28, 2010
    3,446
    Hi, an interesting thing is that in my searches for Arnold Adams & Co. I have found a few Solid Gold American Cased Pocket Watches.
    View attachment 347576 Regards Ray
  19. Dr. Jon
    Dec 14, 2001
    5,017
    15
    Aerospace Engineer
    New Hampshire
    Here is a view of a functional parachute
    [​IMG]
    The red arrow poin tsto th cut Graham mentioned. The green arrow shows where the spring has been thinned to make it supple and the blue arrow indicates cap with is a separate part attached with a screw. Note also that the entire spring is nicely beveled and polished
    This is high level, expensive, workmanship.
    What I had not realized until this thread was that it was highly enough regarded that it was counterfeited. the interesting question to me is who were they trying to fool?.
  20. Omexa
    Feb 28, 2010
    3,446
    #20 Omexa, Jun 22, 2017
    Hi Dr. Jon and others, what I can't understand is if they, whoever they were, went to the trouble to make the part and Spring Steel is not unknown in Switzerland why didn't they cut the slot and thin it to make it work? It didn't work as a Shock Absorber on my Fake movement, my fumble fingered mate dropped mine a short distance onto the Bench and a Balance Pivot broke. Thanks Dr. Jon, I will now be keeping my eye out for a Genuine Pocket Watch or movement. Regards Ray
  21. Omexa
    Feb 28, 2010
    3,446
    Looking at the big Auction site there are 3 for sale by Edouard Favre Brandt. No Slot? Regards Ray
  22. Omexa
    Feb 28, 2010
    3,446
  23. Omexa
    Feb 28, 2010
    3,446
    Hi, it is hard to get a photo of it but the Compensation Curb is Bi-metallic. It looks like Highly polished Steel on the outside curve. Regards Ray View attachment 349867
  24. Omexa
    Feb 28, 2010
    3,446
    #24 Omexa, Jul 12, 2017
  25. Omexa
    Feb 28, 2010
    3,446
    Hi, for those that are interested, here it is with a Mainspring fitted and running nicely. I have a Jacot with the same layout on the Pillar Plate under the Dial. Regards Ray View attachment 349917 View attachment 349918
  26. Dr. Jon
    Dec 14, 2001
    5,017
    15
    Aerospace Engineer
    New Hampshire
    This looks pretty nice. The "real" Breguet parachute and compensated watches, inmy experience are very well made.. This looks to be very late example and Swiss so I doubt were any patnet issues.
    The eduard Favre Brandt watches I have seen are very fine.
Similar Threads - Tobias Breuget Shock Forum Date
Tobias pocket watch age European & Other Pocket Watches Nov 13, 2017
Shock Horror, I have stopped buying movements. European & Other Pocket Watches Oct 4, 2017
For the Tobias enthusiasts European & Other Pocket Watches Aug 28, 2017
Gold cased M. I. Tobias European & Other Pocket Watches Aug 13, 2017
Not, M I Tobias Liverpool, not, M J Tobias Liverpool but "Morris Tobias London"? European & Other Pocket Watches Jul 23, 2017
