To Reverse Paint or not to paint
Discussion in 'Reverse Glass and Dial Painting' started by Royce, Dec 16, 2018.
  1. Royce
    Royce Registered User
    Oct 8, 2018
    165
    32
    Houston
    Looking for an opinion for you restoration experts. Attached is a plate from an Ingraham Venetian Clock I acquired at an estate sale. The plate was broken which I attempted to repair; obviously did not do a very good job. Used Bob Smith Insta-Cure; guess I should have used Hxtal. Anyway, as you can see, the black reverse painting has had some flake off issues. Thoughts on whether I should repair those areas or leave as is would be most appreciated. If I should repair those areas, what would you suggest? My thoughts are not to do anything with the Mosaic portion. Thanks!
  2. klokwiz
    klokwiz Registered User
    Feb 4, 2009
    1,324
    56
    WRENCH
    Annapolis, MD
    Royce,
    If I understand you have glued the glass where it was cracked? if that is the case then if you are satisfied with the re-glue, I would touch-up the missing black spots which is the main detractor. With the glass installed in clock the missing black will not be as noticeable so you may want to look at it that way before doing anything.
    The black may have simply been paint or ink or asphaultum which is a tar like substance.
    Joe
  3. Royce
    Oct 8, 2018
    165
    32
    Houston
    Thanks Joe.
  4. klokwiz
    Feb 4, 2009
    1,324
    56
    WRENCH
    Annapolis, MD
    Royce, your welcome, hope it was helpful. Joe .
