To knob or not to knob...
Discussion in 'Clock Case Restoration and Repair' started by gleber, Feb 28, 2017.
  1. gleber
    gleber Registered User
    Jun 15, 2015
    725
    I just picked up a Jeromes & Darrow, which has a keyhole with escutcheon (which is missing and needs replacement). Initial thread here: http://mb.nawcc.org/showthread.php?140798-Usual-Questions-about-a-Jerome-Darrow
    There was a knob just below the keyhole. The photo shows the hole from the knob, which I removed for working on the door in general. The knob looks like a turned wooden knob, but I think it is actually ceramic.
    The question is, was the knob original, or does it have to go?
    Thanks,
    Tom
  2. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    1,768
    36
    I'd suggest that it is best to leave well alone. Not all clocks have a knob here but it is probably very useful and if not original then a clever addition by someone who cared for their work.
  3. gleber
    Jun 15, 2015
    725
    I'm not sure if it was the same person, but the protruding veneer chip in the top center in the photo is glued on rotated by 90 degrees. So, someone didn't care too much about their work... I have since fixed that (a near perfect fit when done correctly) and would prefer to restore it faithfully.
    It is nice to get your opinion of how to handle it, but I would also like to know if the knob is original or not regardless of how I proceed from here.
    Tom
  4. harold bain
    39,893
    I would guess the knob was added to make the door easier to open after the lock was removed. None of mine have anything like that.
  5. gleber
    Jun 15, 2015
    725
    Thanks Harold. The lock is still there, but the escutcheon is missing. In fact, when I picked it up, the door was locked and the key is missing, so it was sort of a mystery gift. I was hoping to find a stash of cash inside, but only found the weights and two winding keys, but no pendulum bob. I would have said they lost the key and added the knob, but then the knob would not do any good if the door was locked. So it is still sort of a mystery, but I tend to agree that the knob was a later addition.
    Tom
  6. roughbarked
    Dec 2, 2016
    1,768
    36
    Yes. All good points. The reseller may have locked the door with his own key to prevent it falling open?.
  7. Sooth
    Sooth Registered User
    Feb 19, 2005
    3,622
    I vote definitely no knob. I have a Daniel Pratt where someone had screwed-in a small brass knob (an old one) below the keyhole escutcheon, and it just really detracted from the overall look of the clock. I like to keep the keys in the lock with a tassel attached. The locks on these clocks are so simple that they can't easily malfunction or break, so ending up with a permanently locked door is very much unlikely to happen. I use the key every time I need to open the door. I find it much more satisfying.
  8. gleber
    Jun 15, 2015
    725
    I agree that the knob does detract from the look, which is a reason I suspected it is not original. But, I did want to ask rather than assume. The consensus is building for no knob.
    Now the question is how to remove the evidence of it... I'm pretty good at matching color, but have more trouble matching the finish or sheen.
    Tom
Similar Threads - knob knob Forum Date
Ridgeway 9702 glass access panels Clock Case Restoration and Repair Jan 19, 2015
Door Pull/Knob Removal Clock Case Restoration and Repair Jul 13, 2013
Banjo clock knob needed Clock Case Restoration and Repair Jul 4, 2010
Wood Knob Removal for Refinish Clock Case Restoration and Repair May 8, 2010
