Tipsy Coehler
Ken M
Feb 28, 2009
1,742
118
Holiday, FL
The shelf is level, the clock is level and running, the dome not so much. Appears to be contemporary to the clock. Someone did a lousy job of cutting or something, I find it amusing.
Dave T
Dec 8, 2011
4,096
337
NC
Turn it about a quarter of a turn, might be less noticeable.
KurtinSA
Nov 24, 2014
5,255
437
San Antonio, TX
Does the dome sit level on a table top? Does another typical Kundo dome sit more square on the clock? Is this a dome with a flat edge or does it have the rolled edge?
Kurt
Ken M
Feb 28, 2009
1,742
118
Holiday, FL
So I put the dome on a flat table, it doesn't lean, it is square. I put it back on the clock, turned it until it leaned in the opposite direction. So it's the base, but how does it lean in the opposite direction? Unless there is that much variation in the channel, this can't happen.
Bod
Mar 10, 2019
59
When you had the dome on the table, did it lean forwards or backwards?
Bod
Ken M
Feb 28, 2009
1,742
118
Holiday, FL
I tried a replacement dome with a beaded edge, it's straight. This is a cut and ground dome, and it was cut with a slight angle. Cool!
KurtinSA
Nov 24, 2014
5,255
437
San Antonio, TX
You might be able to find an expert in your area who cuts glass and they could try to cut the edge square...or maybe better yet, get it ground...like chance of it shattering.
Kurt
KurtinSA
Nov 24, 2014
5,255
437
San Antonio, TX
Your clock! ;)
Kurt
Dave T
Dec 8, 2011
4,096
337
NC
Leaning tower of Kundo!
Reactions: Ken M
174,396
1,523,873
52,192
danarog
1,063
2,971
Last page
