TIFFANY's Chronograph Pocket Watch, 18K, Two Sub-Dials, Six Hands (Split Second)
Discussion in 'European & Other Pocket Watches' started by Ken Spencer, May 9, 2017.
  1. Ken Spencer
    Ken Spencer Registered User
    Apr 28, 2016
    Rocky Mountains
    This TIFFANY's "Doctors'" Chronometer was obtained via a national TV auction about 15 years ago, and I know little about it. The only maker's mark (that I could find on it) is "TIFFANY & Co" printed above the inner rear casing's hinge, and "Tiffany & Co New York" in script on a bridge in the inner works. The (Tiffany's?) serial numbers are #66429, is also written above the hinges fore and aft in the inner casings. It is 52mm in diameter (without crown). Two second hands on the main face split to record times of two differing events, while the upper minor face records the minutes of elapsed events up until 30 minutes, and the lower face gives the actual seconds. The dial is of white enamel, and the arithmetic digits which surround the perimeter of the main and sub-faces are blacked gunmetal. This watch is NOT repeating. >>> Can you tell if it is authentic, when it was made from the given pictures and if there was a manufacturer other than Tiffany's? Thanx ! ! ! Ken
  2. Omexa
    Omexa Registered User
    Feb 28, 2010
    3,362
    Hi Ken, Pictures:???:?
  3. Omexa
    Feb 28, 2010
    3,362
    Hi Ken, if you don't put photos on the forum, it is impossible for people to give you advice about it. Regards Ray
  4. Ken Spencer
    Apr 28, 2016
    Rocky Mountains
  5. richiec
    richiec Registered User
    Feb 24, 2007
    5,471
    automotive warranty inspector
    Brick, Ocean, NJ
    Photos did not come through, try again.
  6. Tom McIntyre
    Tom McIntyre Technical Admin
    Staff Member Donor Sponsor NAWCC Member
    Aug 24, 2000
    77,850
    396
    146
    retired SW dev
    Boston
    #6 Tom McIntyre, May 22, 2017
    These are the pictures are Ken's watch - Kevin
  7. tgarnold
    tgarnold Registered User
    Jun 14, 2012
    168
    It's a beautiful rattrapante chronograph. It is definitely finished at a level appropriate for a Tiffany pocket watch. Someone else may know more about the maker based on the serial number, but I wouldn't worry about it being authentic.
  8. eri231
    eri231 Registered User
    Jan 13, 2012
    1,048
    torino italy
    this chronograph was made by Agassiz with a LeCoultre ebauches
    regards enrico
  9. Ken Spencer
    Apr 28, 2016
    Rocky Mountains
    Hey Kevin, Thank you ever-so-much for helping me get my photos published and for identifying the Tiffany's Chronograph as official! Thanx again, Ken
  10. Ken Spencer
    Apr 28, 2016
    Rocky Mountains
    Hey Enrico, Thank you for further identifying my Tiffany pocket chronograph as being Agassiz. I would assume that "ebauches" refers to the bridges. Thanx again ! ! !
  11. Nachtmotte
    Nachtmotte Registered User
    Nov 21, 2005
    356
    Greece
    Sorry Enrico for disagreeing, but if it was done by AGASSIZ, it would have been signed like "Made for TIFFANY & Co. by AGASSIZ W. Co.". The font on the bridge looks like the same as AGASSIZ, but this doesn´t ment to be an AGASSIZ watch. Better to cross check under the dial for the fish symbol..., but in this case the owner shouldn´t disamble the watch! Indeed a very nice condition.
    The genuine AGASSIZ Watch Co. serials for this calibre layout were:
    117.xxx - 118.xxx,
    122.xxx,
    244.xxx - 245.xxx,
    334.xxx - 335.xxx
    (case and movement serials have to be identical)
    @Ken Spencer
    This calibre is a LeCoultre 22 "Remontoir dessous le pont de barillet" - 19 lignes WCRV, made by LeCoultre & Cie for Tiffany. The Agassiz Watch Co. had nothing to do with this movement
    My best regards
    Antonios
    _____________________________
    http://www.faszination-uhrwerk.de
    tick talk likes this.
  12. eri231
    Jan 13, 2012
    1,048
    torino italy
    chapeau of course you're right
    regards enrico
  13. gmorse
    gmorse Registered User
    7,202
    22
    Retired from Xerox
    Hi Ken,
    No, the term (singular) means the whole basic movement, in this instance made by LeCoultre, which would have been more or less modified and finished to their own specifications by Tiffany.
  14. tomczc
    tomczc Registered User
    May 13, 2016
    34
    The movement is from Agassiz, hight quality
Similar Threads - TIFFANY's Chronograph Pocket Forum Date
Old chronograph movement...Brevet 927 European & Other Pocket Watches Sep 27, 2017
Repeater chronograph calendar European & Other Pocket Watches Sep 11, 2017
how can I authenticate my Tiffany's pocket watch? European & Other Pocket Watches Jun 29, 2016
Is the Tiffany's pocket watch produced by Patek Philippe? European & Other Pocket Watches May 13, 2016
Who is the Manufacturer of my Tiffany's open face repeater pocket watch ? European & Other Pocket Watches Feb 22, 2013
