Recently acquired this clock. Need a little help restoring it.
I need one coil and an original shunt resistor. If you have either or both please contact me via private message giving your email address and I will respond.
The clock was worked on by a DIY who clearly did not understand what is required to fix it. Used lots of acid core solder and in general made a mess of it.
I have a few questions about the interrupter.
There was a small wire loop that seems to have been a spacer on the end near the interrupter plate. Was this somehow part of the wiring possibly to supply a ground?
On the other end of the interrupter was a small flat wire ribbon that originally appears to have wrapped similar to a hair spring that was soldered to the lead wire. Was this the connection to the shunt resistor?
What is the surface metal on the contact surface of the interrupter? I know the pin that sides on it is silver.
Can the interrupter be cleaned in an ultrasonic or is just contact cleaner best.
