Tiffany & Co. Chelsea Movement Issues
Discussion in 'Clock Repair' started by scott64a, Feb 18, 2017.
  1. scott64a
    scott64a Registered User
    Jul 31, 2013
    362
    Clockmaker
    Harvard, MA
    Hey all,
    I've recently overhauled this Chelsea movement for a customer, and while in there I noticed that the adjustment lever for the rate had been silver soldered at some point. Also, the hairspring seems OK, but no matter what, the ticking isn't even.
    It ran well for me for the requisite three week testing and rating period, but after a month with my customer it has stopped again.
    The bushings all look fantastic -no wiggle, proper end shake. Pivots are all smooth and polished. Springs were stripped and cleaned, lubed with light mainspring grease.
    Really, my chief suspicions regarding this movement are that the hairspring has been altered or bent in a way that puts it out of beat.
    It has always been my practice to just replace the balance wheel and hairsprings in these and pocket watches as I lack the tooling necessary to vibrationally match them up or check the balance of the wheel.
    Usually, and in 98% of the cases, one can source a parts movement and simply swap the hairspring and balance staff out, but here I am stuck without a ready source of parts.
    Chelsea... they like to keep their parts hidden away and not for sale to repairmen or the public.
    So...
    -Does anyone have a procedure for setting up this hairspring?
    -Does anyone have a match for this hairspring and balance wheel that I may purchase?
    -Does anyone work on hairspring/balance wheel assemblies where I could send this off and have the work done?
    I told my customer it would be a while before he got his clock back, and he's quite OK with that.
    I think this may be the last Chelsea movement I work on, honestly.
    Any info would help greatly.
    Thanks!
  2. Kevin W.
    Kevin W. Registered User
    20,163
    10
    Any pictures of the movement.
  3. Tinker Dwight
    Tinker Dwight Registered User
    13,680
    #3 Tinker Dwight, Feb 18, 2017
    You can set the beat by rotating the collar for the spring. You can usually
    take a jewelers screw driver and rotate the collar by putting it in the slot
    and using it as a lever. Hold the balance wheel so as to not load the pivots.
    The spring needs to pass cleanly through the regulator and not put
    significant side pressure on the balance wheel.
    Also check the lever arm. I just got a clock running that has the lever
    arm as a separate piece then the pin pallets. It was badly adjusted by
    some earlier person ( not the only problem ).
    To run right, the lever must lock clear of the roller and balance wheel
    arbor. Poor power will not do this well. The clock will run fast if it
    doesn't lock ( often people fiddle with the regulator to try to fix this
    and break something ). It will run fast until it finally stops, that is.
  4. scott64a
    Jul 31, 2013
    362
    Clockmaker
    Harvard, MA
    Heh, I meant to add one.
    [​IMG]
  5. Tinker Dwight
    13,680
    #5 Tinker Dwight, Feb 18, 2017
    Does that have the hair spring that goes over the top of
    the rest of the spring?
    If so, it is a special way to route the spring to keep it isochronal.
    It is not an error.
    The method I mentioned should still adjust the centering of the
    roller. You can ignore anything else I said about the hair spring and
    regulator.
    I'd guess the silver soldering was original.
    That is a nice bimetal balance wheel.
    You might check the lever location at each drop.
    The lacquor holding the stones can age and lose there position.
  6. scott64a
    Jul 31, 2013
    362
    Clockmaker
    Harvard, MA
    It does, and it looks like it's been tweaked as the coil is collapsed; more than it should be.
    I'm in contact with Chelsea, and have given them the ser. number so they can check around.
    The silver soldering is definitely not original on the adjustment lever -it's been patched after a break it looks like.
    Good tip about the lacquer. If I can, I'll just get a whole new assembly. I don't have the tools to vibrate and match the wheel, spring and staff.
Similar Threads - Tiffany Chelsea Movement Forum Date
Chelsea Boston Shipstrike Clock Clock Repair Aug 29, 2017
Guardier/Tiffany brass clock 9V type movement "GYR". Clock Repair Sep 20, 2011
Quartz Replacement for Tiffany Clock Clock Repair Mar 14, 2011
Large German "Tiffany" Westminster synch. Clock Repair Feb 11, 2010
Tiffany Carriage Clock Glass Question Clock Repair Jul 3, 2006
