Thread Pitch on 8mm Chuck
Discussion in 'Horological Tools' started by KurtinSA, Jun 1, 2018.
  1. KurtinSA
    KurtinSA Registered User
    Nov 24, 2014
    3,145
    96
    Aerospace Engineer (Ret.)
    San Antonio, TX
    I purchased what appears to be an 8mm 6-jaw chuck at an estate sale...diameters match the 3-jaw that I have. I'd like to see about cleaning up the threads on this new chuck. What is the size needed in order to clean these threads up? The diameter of the solid portion of the shank is 8mm, but the diameter across the threads is 6.7mm.
    Thanks...Kurt
  2. KurtinSA
    Nov 24, 2014
    3,145
    96
    San Antonio, TX
    Found out they're buttress threads...not sure exactly which kind. Only a special die would work. The threads weren't that bad...I just cleaned them up some brake cleaner and a toothbrush.
    Unknown 10mm lathe
    Kurt
  3. wefalck
    wefalck Registered User
    Mar 29, 2011
    464
    25
    Geochemist (Consultant)
    Paris
    Are you sure they are buttress threads ? Never heard of any such thread on 8 mm-collets. Normally the thread is 6.8 to 6.9 mm diameter and 40 TPI, symmetric.
  4. KurtinSA
    Nov 24, 2014
    3,145
    96
    San Antonio, TX
    I did measure approx. 6.7-6.8 mm across the threads. I'm no machinist...I was just told they were buttress threads. I tried using my loupe to look at the threads...hard to tell, but they might just be symmetric.
    BTW...no manufacturer that I can find on this chuck.
    Kurt
  5. wefalck
    Mar 29, 2011
    464
    25
    Paris
    I gather the key question would be: does it fit the draw-tube of your lathe ? Or, would it fit the draw-tube for other known lathes ?
    You could count the number of threads per inch (or per centimetre). The pitch of thread for all 8 mm-lathes seems to be 40 TPI. The diameter, however, varies between 6.68 and 6.85 mm from manufacturer to manufacturer. A smaller diameter collet fits into a larger draw-tube, but obviously not vice versa. You can measure the collets you have, if they are larger than the shaft of your chuck, you should be lucky. If they are smaller than the shaft of the chuck, you may need to get a thread-chasing die of the right diameter for your lathe. With this you can reduce the thread diameter of the shaft of your chuck. These dies can be now found a quite reasonable price on the Internet and are useful for cleaning up threads anyway.
  6. KurtinSA
    Nov 24, 2014
    3,145
    96
    San Antonio, TX
    Thanks...the chuck fits the draw tube of my Levin lathe. It was when I first used it without any cleaning, it didn't seem to draw up tight enough. I used the toothbrush and a cleaner on the threads and it seems to work better. I have a 3-jaw chuck but wanted to try a 6-jaw to see how it might work.
    Kurt
  7. trim
    trim Registered User
    Feb 19, 2010
    151
    WW should be 0.275-40 and are sold each and every day on ebay. The RDG ones are very nice.
  8. wefalck
    Mar 29, 2011
    464
    25
    Paris
    ... should be, but If you have a look at the table in Carlè's book, you will see that the diameter varies from manufacturer to manufacturer.
  9. flynwill
    flynwill Registered User
    Feb 1, 2007
    1,024
    7
    Rolling Hills Estates, CA
    I created this page in our "encyclopedia" some time ago: https://mb.nawcc.org/wiki/WW-Collets
    There are both 40 TPI thread and 0.625mm pitch (40.64 TPI threads), and also 0.75mm threads on the new ones from the Orient.
