Thomas Haller Mantel clock restoration
Discussion in 'Clock Case Restoration and Repair' started by KBwindup, Nov 17, 2019.
  1. KBwindup
    KBwindup Registered User
    Apr 23, 2017
    39
    Hi all
    I ve been lucky enough to find my Great Grandmothers clock, unfortunately it's in horrific condition but has a lot of sentimentall value to me so I intend to restore it as best I can.
    I m assuming that the movement is second half of 1912 going by B12 ? , which seems a long time since Junghans took over Thomas Haller circa 1903.
    Has any body a similar Haller clock? obviously the front door is missing and I d love to make one as close as possible to the original.
    The other problem I see us the dial. I m very open to suggestions on the best way forward restoring it to an nice standard. I ve quite often repainted dials with Roman numerals but if I m not so confident doing Arabic numerals.
    The main case I gave left is approx 12 1/4 inches (310 mm ) high and 7 inches (180 mm) wide.
    Any help on this restoration would be much appreciated.
    Eamonn
    20191117_130739.jpg 20191117_131043.jpg 20191117_131135.jpg 20191117_125348.jpg 20191117_130814.jpg
  2. shutterbug
    40,799
    730
    I'll move this over to case restoration forum for now. When you get to the movement, we can bring it back here ;)
  3. JimmyOz
    JimmyOz Registered User
    Feb 21, 2008
    225
    27
    Although I have not done this myself have a look in the watch section as I am sure there must be info on how to make a transfer/decal as they make them for watch faces.
  4. KBwindup
    Apr 23, 2017
    39
    Thanks Jimmy, I ll have a look and see.
  5. shutterbug
    40,799
    730
    Here's one that I did with just a printer, paper, and a picture. I used a picture editing program to fix the bad areas. The original is below, for comparison.
  6. JimmyOz
    Feb 21, 2008
    225
    27
  7. KBwindup
    Apr 23, 2017
    39
    Thanks for that information, I ll definitely try that!!! Great job I must say.
  8. shutterbug
    40,799
    730
    It did take patience. I had to expand the size so I could deal with the small areas ... but it was satisfying to get it looking right again ;)
