18th c English Thomas Cartwright, magnificent bracket clock
zedric
Aug 8, 2012
1,956
404
I would assume that the Etherington is a bit earlier than mine - sine I bought the Cartwright clock I have seen a few like that which have side panels with violes in so that you can view the movement, but they are all a bit earlier. Mine seems to be designed to have coloured silk behind the panels
NigelW
Jan 2, 2015
556
82
London and Kent
I think the Etherington is about 1700, so maybe ten to fifteen years older? Do you have a copy of Sunny Dzik's book on backplate engraving? Yours is what he describes an asymmetrical vine engraving with a frond cartouche; the cartouche style he puts at 1700-1720.
zedric
Aug 8, 2012
1,956
404
I haven't purchased that one yet, so good to know. My best guess on this clock is that it was made 1750-120, but probably closer to 1715.
I've done a bit of research on Cartwright since I first posted this thread, but there is not all that much info around, especially considering that he was *the* Royal Watchmaker to King George II, the same position that was held after he died by Benjamin Grey, who is far more well known. One problem in resaerching him is that there were so many more famous Thomas Cartwrights, including a Cartwright who was designer for the Royal Exchange - so searching for Thomas Cartwright Royal Exchange (Cartwright had a shop there probably on the Threadneedle street side) does not help...
Reactions: NigelW
NigelW
Jan 2, 2015
556
82
London and Kent
Are you planning to convert it back to verge? If so I would be most interested in seeing how you get on as I have the same road ahead of me.
zedric
Aug 8, 2012
1,956
404
At the moment, lack of skills, and lack of budget, mean that I am focussing on getting the case restored, and the movement serviced with all functions (including moon phase) back in order. So unfortunately conversion back to verge will have to wait...
novicetimekeeper
Jul 26, 2015
11,792
1,174
Dorset
Wonderful though this is, my price for selling my soul would be nothing short of a Tompion.
There was a Tompion longcase went 2-3 years ago for £30000. However a small Tompion bracket went for £1.2 million more recently. It was a bit special. No complications, just the best provenance.
Reactions: NigelW
DeanT
Mar 22, 2009
1,706
566
Australia
I really enjoy the detailed and long threads on early English clocks. With a bit of luck we can see further photos of the movement and case now its been moved to the restorers.
zedric
Aug 8, 2012
1,956
404
Hi Dean
Movement is now with the restorer, so I have some more photos to share - so far just as received. No idea why they made such an inappropriate choice for the fusee cable..
DeanT
Mar 22, 2009
1,706
566
Australia
Am I right in thinking they cut the mock pendulum aperture back plate to allow the pins to drive the moon phase?
zedric
Aug 8, 2012
1,956
404
It's difficult to tell just from the photos. From what I can see, I'm guessing that someone didn't understand how the date was supposed to be driven (which seems to be via the inner set of 6 pins you can see on the upper of the two wheels connected to the hour). So they added a pin to the moonphase wheel to drive the date wheel, then had to cut the mock pendulum backplate to accommodate that. Then at some later stage the pin for the date wheel has been put back on the lower of the two drive wheels.
How someone who owned a clock like this allowed someone to work on it who was stupid enough to use that wire is one of the things I will never understand. At least with the restorer Nick has put me on to it is in good hands now...
Ralph
Jan 22, 2002
5,449
379
Phil, what a great clock and maker. Congratulations.
To throw another speculation out there….. could the moon phase and it’s associated parts be a later modification? The 6 pin wheel might be a repurposed date drive wheel. It also looks like it may have had a night shutoff at one time.:???:
It’ll be interesting to see what Nick’s restorer concludes.
Is the clock in England?
Ralph
Ralph
Jan 22, 2002
5,449
379
Phil, here is an image from Barder's book on Georgian Bracket Clocks. It is by Claudius du Chesney. It has a very similar lunar indication on it's dial.
I noticed after posting this, Dean has already discovered. Youth. ;)
Here are some spandrels for Loomes, Brass Dial Clocks book.
Ralph
Jevan
Jul 31, 2014
99
54
Although the movements bear little relationship here’s another Du Chesne with a penny moon.
It is interesting that rather than two times 29 ½ the age of the moon is engraved up to 59 days and the moon drive appears to be a series of idle gears.
Reactions: Ticktocktime100
zedric
Aug 8, 2012
1,956
404
Ralph
Hi Ralph
I am fairly sure that the moonphase on this clock is original - the penny moon style was used on bracket clocks by a handful of makers around this time, when makers were experimenting with what to put in the arch (DuChesne being the main one I have found, but I have also seen another clock by James deFontaine which has this feature). The drive to the moonphase is similar to that used by others. For example, see this one, which while not identical (it drives from a bevel gear rather than an arrangement of pins) uses the same type of shaft to take the drive to the moon wheel.
What neither the restorer nor I can work out is why someone added an extra pin to the moon drive wheel that necessitated a cut out in the backing plate for the false pendulum bob. Apparently this is not in the correct place to engage with the date wheel, so couldn't have been for that.
I am interested in your comment about the night shut-off. The clock has strike/silent, although the lever for that is missing at the moment. What are you looking at that makes you think there was once a night shut-off?
zedric
Aug 8, 2012
1,956
404
To follow up on the comment about the hole for the extra pin, it is the one shown in Red on the photo below. The one in green is the drive for the date wheel,. There are separate wheels to drive the date and moonphase. The moonphase is driven by the arrangement of 6 pins on the wheel with the red marking - these pins engage with the shaft that is connected to the back of the dial plate.
If anyone has any ideas about why the hole highlighted in red was made (which necessitated cutting a segment out of the backing plate for the false pendulum bob) I'd love to know!! Apparently it is too low to engage with the date wheel.
Reactions: Alex KVASHIN
Ralph
Jan 22, 2002
5,449
379
A
Hi Ralph
I am fairly sure that the moonphase on this clock is original - <snip>t
<snip>Apparently this is not in the correct place to engage with the date wheel, so couldn't have been for that.
Seeing the Du Chesne clocks, I can see that it is not a stand alone configuration. I'll still leave the door slightly open where the 6 pin wheel might be a later repair by a lesser clockmaker. :???:
I may have been loose with the "night shutoff" term for the "no-strike-strike" switch?? I wasn't suggesting automatic night shutoff.
Ralph
novicetimekeeper
Jul 26, 2015
11,792
1,174
Dorset
Has Peter worked out why the arbour that drives the lunar display runs up in front of the backplate for the mock pendulum aperture rather than behind it?
zedric
Aug 8, 2012
1,956
404
Turns out it was just fitted incorrectly. The plate fits in front of the arbour just as well as behind it
novicetimekeeper
Jul 26, 2015
11,792
1,174
Dorset
Ah, I had wondered about that, I had a look at it myself and thought that might be the case but the cutout misled me, I thought it might be to go over the mounting at the bottom, I didn't know about the extra pin.
zedric
Aug 8, 2012
1,956
404
This is taking its time in restoration. The case is coming along nicely, but the movement hasn't been started yet... Photos of the case with the doors removed - looks like the gilding has survived fairly well...
This is not my work (I wouldn't know where to start on something like this), but done by Scott who does work for novice and Dean.
Here is a before picture for comparison
The basket top is apparently quite thin metal, and needs to be properly reattached so it may look a little less wobbly when finally done. But the ebony veneers (apparently real ebony rather than ebonised fruit wood) and metal mounts have been restored superbly! Still needs a set of finials for the upper basket top, which will have to be made.
Still don't know where I can get spandrels to fit in the corners of the dial (see picture below) as these are an unusual shape - if anyone has any ideas, please let me now!
DeanT
Mar 22, 2009
1,706
566
Australia
That looking really good, befitting the quality of the clock and movement.
You could ask either of these two companies for spandrels. I think Devon does the casting for optimum but they might have a mould that might work for that shape.
novicetimekeeper
Jul 26, 2015
11,792
1,174
Dorset
That is looking stunning Zedric, I was going to visit Scott but that was the week my Mum got sick from Covid so I didn't go. I look forward to seeing it in person.
zedric
Aug 8, 2012
1,956
404
Hi Dean - thanks - I'll pass these on to Peter, who is doing the restoration of the movement..
Cheers
Phil
zedric
Aug 8, 2012
1,956
404
So, both the movement and the case are now almost finished, but not yet back together. This shows the fantastic level of craftsmanship that is still around (I did NOT do this work myself!). Have not yet decided on the upper spandrels
Dial - final.JPG movement 3:4 2 final.JPG
rmarkowitz1_cee4a1
Nov 26, 2009
6,274
1,492
View attachment 702039 View attachment 702042
View attachment 702044 View attachment 702045
Superb.
There is a side view you posted earlier. I realize that that picture was taken minus the front and back doors, but, none the less, I just love how wonderfully slender the case is! IMCO, adds a gracefulness to the clock.
RM
Philip Snowden
Sep 19, 2021
53
24
78
At one time 9 years ago I used to own this clock by Langley Bradley about 1690 until I sold it along with a lot of other clocks to help my son with his first home .I regretted it at the time but hey one gets over these things .But it was a lovely clock to own for a few years.Sorry pictures not great .
E8FF4690-0FAF-4669-BD40-9593E3F112C3.jpeg FB380ADE-AD93-4351-A72B-D32C72ED4710.jpeg
Reactions: zedric
zedric
Aug 8, 2012
1,956
404
Better to have loved and lost... A beautiful clock
demoman3955
Apr 9, 2022
152
65
It's just okay.
When you get it home and you don't like it, I'll pop over and take it off your hands. :rolleyes:
But in all seriousness it's magnificent. Obviously needs a bit of restoration but its well worth spending the time and money on this one as it will benefit greatly with some cosmetic tidy up to the case.
I've got a couple of arch spandrels we might be able to cast which might fit although yours is quite small given the engraving. Easy enough to find something.
Golden age. :) Apprenticed to famous maker Gould. :) Clockmaker to Queen Anne and George I. :) Moonphase :) Quarter repeating on multiple bells :) Magnificent case and engraving :):):)
So being new here, i think its a good place to ask about whether to restore or not to restore. I know its subjective, but all my clocks are mostly as i get them other then cleaning and repairs that may hinder its safety or function. I have a late 1700s (or so im told) grandfathers clock, and you can see bad spots and a few cracks in the wood, and im good with that. just wondering what other clock people think.
DeanT
Mar 22, 2009
1,706
566
Australia
I would suggest starting a new thread and post photos of your clock and get some advice on how to restore it.
demoman3955
Apr 9, 2022
152
65
hahaha thats a lot of photos even if only one per clock. I was just thinking (which is a bad idea) about what most seem to prefer. I personally prefer the flaws of the life of things. My house is over 100 years old, and has wood floors that show many years of use or abuse, but i like it as long as its not a safety issue.
novicetimekeeper
Jul 26, 2015
11,792
1,174
Dorset
As Dean said, it is better to start a new thread for your collection, or individual clock, or your discussion about conservation. This thread will then be for discussion about this clock or this maker, which will then be a reference for others interested in the subject matter. Photos loaded onto the server in the thread you start will then be available for research by others into those clocks, long after we are gone.
Reactions: demoman3955
zedric
Aug 8, 2012
1,956
404
These are the spandrels I've settled on for now for the corners (see loose spandrels sitting on chapter ring) - will need to find the best way to attach them temporarily until I decide if these are the final ones, or if I should keep looking. As Sooth says, they are cut down from larger spandrels. My key thing was to keep with the floral theme, and there were not many spandrels with flowers to choose from.
Clock won't be here for a while, so if anyone has any better suggestions, I'm open to them!
Reactions: jmclaugh
WIngraham
Apr 19, 2019
231
103
35
Looks amazing. A remarkable restoration.
Optimum brasses has a similar small spandrel in their supplement catalogue. Part F142L. Is that the one that you pictured? It's hard to tell. I think it would fit. It's on pg 7.
Will
zedric
Aug 8, 2012
1,956
404
Hi Will
Yes, that is the one that was used - needed to be cut down a bit to fit. The biggest challenge is that the engraving on the dial is slightly asymmetric, so either the spandrels will need to be placed slightly out of position left v right to allow all the engraving to show, or the spandels will be placed symmetrically, which will cover a small portion of the engraving.
WIngraham
Apr 19, 2019
231
103
35
Hi Zedric, you definitely scored on that clock. I remember when I first saw it scrolling through listings.
I thought it did look similar to the one in the catalogue. If it were mine, I would position them symmetrically. I think I would find the asymmetrical placement distracting, compared to a slight covering of the engraving. But it is hard to say without seeing it both ways first, asymmetry can be attractive.
Will
zedric
Aug 8, 2012
1,956
404
Hi Will - I'm with you, I think slightly covering the engraving would be a better option. But the restorer who worked on the clock, and had it in front of him, felt it looked better with the spandrels slightly askew. Once I get the clock here, which is a while yet, I'll make my own decision, but I guess we'll never really know what the original spandrels looked like.
WIngraham
Apr 19, 2019
231
103
35
Ah I guess it will be a decision to be made in person. Please post pics and/or a video lol. Clocks like this are better shared.
Will
173,674
1,516,552
51,881
Fibee
1,062
2,969
