Most visitors online was 1660 , on 12 Dec 2020
I'm not sure that is the case here - there are protruding pieces from the tube the stem goes through that seems to preclude rotating the movement (if you look at the movement shot).It is a long time since I've worked on one of those but from memory the whole movement needs to be rotated until it reaches the sweet spot.
