the south wall
bruce linde
ADMIN / MODERATOR
8,356
1,173
oakland, ca.
clockhappy.com
this post is an expression of appreciation and thanks to the many folks on the message board who have helped me since i first showed up as a clock enthusiast ten-ish years ago. that help has included an amazing amount of repair and servicing advice and coaching... and resulted in this, the south wall of my home office... with nine pendulum clocks:
here are the clocks, with links to their original forum discussions... i know that some of these are marriages that no serious collector would consider, but each one was a find, a score/deal, and/or a learning experience. p.s.: i know the real repair guys have been doing all of the tasks mentioned below every day for years, but you'll always remember your first time!
from left to right:
8-day 1.5x scale wood movement clock in custom case, beats seconds
completely re-bushed (with DelrinAF, thx to r. croswell)
atkins 1875 30-day extra with upside-down movement and curved moldings
lots of bushings, including custom-lathed great wheel bushings front and back, kludged pendulum, non-original weights, repaired counter-balanced minute hand
1865-ish seth thomas #1 with round terry movement... all original except for the tablet done by tom moberg
cleaned, serviced, that's about it
1840-ish biedermeier vienna regulator
cleaned, serviced, escape wheel moved slightly to avoid pallet wear
(what's left of a) 1914 franke tall case (and now, wall) clock
serviced, pendulum kludged, falling apart case glued back together
standard electric time movement / unkknown case marriage
a true frankenclock comprised of disparate pieces: standard electric time movement (with very worn escape wheel teeth), kludged pendulum, seth thomas 8" bob, mystery case, synchron motor (and gearing) added, entry verge refaced with slipper
waterbury no. 4 (aka rosedale) time-only double-wind regulator
serviced
mystery jewelers regulator movement
serviced, kludged pendulum, custom wood support
1884 gothic vienna regulator
serviced, broken rack repaired
JimmyOz
Feb 21, 2008
783
164
65
Gold Coast Qld
I am impressed, not only the varity, they all look to be on the same time :clap:
P.Hageman
Jul 20, 2014
1,115
223
The Netherlands
What a nice wall you have there and what a nice gesture! I can only aggree with you, this messageboard is so pleaseant and helpful in so many ways.
nutmegtinker
Dec 25, 2020
CT
A great inspiration for someone new like me. You are presenting the fruits of a rich experience that reflects your individual character and the support of this wonderful community.
46,175
1,773
Nice clocks! But that one on the floor is a real dog. :D
PatH
Dec 5, 2014
2,120
1,563
Texas
Great wall, Bruce! Is that a clock on every other wall stud, or some other spacing?
bruce linde
ADMIN / MODERATOR
8,356
1,173
oakland, ca.
clockhappy.com
the best part is i posted on a monday afternoon, and wind (and regulate) them tuesday mornings... which means they're all running pretty close. in fact, i just now finished the morning wind (a little late because of an early meeting and then a tennis hit), and the worst one was the standard time w/ synchron motor, that i've just begun regulating. every now and then i'll get lucky and go to regulate one and it's dead on (woo hoo!). it's a little tough up here in hills... sometimes i have the doors and windows open, sometimes it's hot and dry (and sometimes cold and humid), and that particular wall is an exterior wall... gives me something to look forward to each week. :)
The guitar is out of tune! Nice collection!
that, my friend, is a very rare martin B-540 acoustic bass guitar, with (ridiculously expensive) nylon core strings (acousticore) that make it sound like an upright bass... and it's always in tune! :)
Reactions: D.th.munroe
bruce linde
ADMIN / MODERATOR
8,356
1,173
oakland, ca.
clockhappy.com
sorry... forgot to respond to this one.
the heavier clocks are secured to studs. i use 100 lb hooks for the others, typically w an additional screw through an existing hole in the inside back into a stud (which means they don’t have to be centered on studs)... or at minimum, sheetrock. that gives a bit of stability and keeps the clocks from moving when doors are opened.
mostly, i move them around and space them so they look their best next to each other. sometimes i’m matching reverse painted glasses, or considering how much reflection from what angles, etc. my sense of aesthetics might not match everyone else’s, but finding a balance that works for me for each wall in each room is part of the fun of getting a new clock... it’s like a chess match. :)
Reactions: PatH
164,878
1,434,708
85,843
Wagons
2,872
