I had replaced several worn bushings on the identical and similar clocks using American Made #L-43 & L-40 Brass Bushings.
On this movement, however, these large bushings are worn (oval shape), and they look different from those above. They appear to be riveted or, perhaps, two pieces inserted into each other? It's hard to tell as I did not clean the plates yet.
How do I replace these particular bushings? Thanks
