The Repair Shop BBC series
Discussion in 'General Clock Discussions' started by AusDan, Jun 30, 2019.
  1. AusDan
    AusDan Registered User
    Apr 22, 2013
    Scientist
    South Australia
    I've been watching this show on TV lately and find it a refreshing look at craftspeople sharing their skills. This episode made me wonder if that really was the only way to remove the movement from that donor clock or was it just the quickest?
    depatty likes this.
  2. tracerjack
    tracerjack Registered User
    Jun 6, 2016
    839
    62
    Female
    Lodi, CA
    Just the quickest is what I think.
  3. mauleg
    mauleg Registered User
    Dec 26, 2012
    848
    138
    Since they do not show much of the donor clock prior to its destruction, it's hard to say what options were available, but I'm fairly certain that the drastic actions of the presenter were likely unnecessary.
  4. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    3,493
    210
    watchmaker
    Being what appears to be an insertion movement. Technically the destruction of the case would have seemed unnecessary because the whole movement should simply slide out through the front of the case. I can only assume that apart from speed or dramatism, it could be possible that since the dial was the only part required the repairer wanted the dial intact and the wooden case may have been slightly distorted which could possibly have caused damage to the dial while being removed. Hence, break the case apart gets the dial without risk of further damage?
  5. Les harland
    Les harland Registered User
    Apr 10, 2008
    1,395
    116
    Hertfordshire England
    Assuming the movement was beyond economic repair why wreck what appears to be a sound case?
    A suitable movement could turn up at any time
  6. jmclaugh
    jmclaugh Registered User
    Jun 1, 2006
    4,285
    80
    Devon
    No prisoners taken there but as has been said you'd think the movement would slide out though the drum that holds it is usually secured to the inside of the case.
  7. shutterbug
    40,767
    720
    Pretty drastic. Certainly not necessary. The case wasn't formed around the movement when it was made, so if it went in, it should come out.
  8. roughbarked
    Dec 2, 2016
    3,493
    210
    watchmaker
    It is all certainly at odds with the theme of refurbishing. Seems melodramatic at best.
  9. Les harland
    Apr 10, 2008
    1,395
    116
    It probably "looks good" on television
  10. Ralph
    Ralph Registered User
    NAWCC Member Sponsor
    Jan 22, 2002
    4,689
    75
    The problem is is that the wood shrinks and locks the cylinder sleeve in place It was probably the most expedient way to remove the movement, as the unwanted case would probably be damaged regardless in a careful removal attempt.
    IMHO, Ralph
    instarclock and depatty like this.
  11. roughbarked
    Dec 2, 2016
    3,493
    210
    watchmaker
    The only thing that was required undamaged was the dial.
