This just came today - I had splurged on it as a birthday present, and for once, the seller and the USPS timed its arrival perfectly! Woo-woo!
With interesting variations, which I hope Mr. Hubby can elucidate with his usual excellent knowledge, this looks like Clock #9 in Section 6 of Terwilliger 10, back plate #1475 and pendulum #3. The bracket and saddle are very similar, but not identical, to #17 in Section 15.
The variations:
The base is wood, not brass. (The circumference of the groove is 5.75", slightly larger than any of my domes.) The pillars are attached with screws, not nuts, and there are three holes around the circumference that look like some sort of feet may have been attached.
The three-pillar gallery pendulum has four circular cutouts in its base; the Guide's photo shows a solid disc. (The pendulum has no number; presumably it would have been on a bottom cover, which is not present). There is a ring of lead fitted within the base. The bottom block is not pinned with a cotter pin as in the photo in Section 13, but has a split brass plate with screws to hold the spring.
The back plate has the serial number 5154 placed just to the right of and slightly below the click, but no "R". The Guide states in the Appendix, #23, "Serial numbers 913R to 2991R have been identified for clocks having disc pendulums with no gallery, c. 1882 - c. 1884. Those with serial numbers 4722R to 5558R have been identified for later clocks with pendulums having a 3-pillar gallery, c. 1885.". The click is missing, but the threaded hole is there. There are two additional holes that align in the plates that are not shown in the Guide, and I can't imagine what purpose, if any, they served. The back one is simply a hole - no oil sink, and the front one appears to have been bushed, badly.
As mentioned, the suspension bracket and saddle are similar to the Phillip Haas (sic) one in the Guide, but the block has a rounded top edge rather than flat. The block is two pieces - the block itself has a cylindrical bottom which fits into a round brass dick and is fixed with a screw. The disc has two heavy pins which fit into a cradle on the bracket, allowing free movement front to back. The bracket also has two sets of threaded mounting holes - the top ones are in use at present.
The enameled dial is obviously a replacement (it's marked "8 days"!), and it has two copper pins on the back, while the dial back plate is drilled for four. I suspect the hands are replacements as well - the Guide shows "moon" hands, and the hour hand on this clock extends a tad too far past the chapter ring.
So what do I have? Is this a marriage of base, movement and pendulum? Is it an undocumented oddity? Inquiring minds want to know!
The variations:
