The hardest clock to wind in your collection?
Isaac
Aug 5, 2013
1,208
319
For me, it's the chime mainspring for this W&H chime clock. It's a massive spring that feels like you're winding a Sonora chime clock without the assisted winding gearing. What is the hardest clock to wind in your collection so far?
bruce linde
10,883
2,536
oakland, ca.
clockhappy.com
funny - i just asked david labounty and my clock mentor yesterday if i should try lighter mainsprings in my quarter-striking W&H. :)
5,809
1,014
The chime spring in my 1909 Junghans Westminster chiming bracket clock.
Dave T
Dec 8, 2011
4,482
472
NC
Clocks that wind to the left instead of right. Such as this Junghans.
Schatznut
Sep 26, 2020
1,560
866
SoCal
My Atmos. Danged if I can figure out where the key goes.
Elliott Wolin
Nov 18, 2019
607
118
69
Williamsburg, Virginia
For some reason, the strike spring is really hard to wind on my Ingraham clock. I replaced one of the springs, don't recall if it was the strike or time mainspring.
So I made a combination spring letdown and winding tool. The thin dowel at the end is removable, usually necessary when letting down a mainspring (or else your wrist gets whacked multiple times, guess how I know this!).
Richard.W
May 4, 2021
432
182
72
NE Georgia
A Gustav Becker... because the right-handed front door only opens 90° making me need to use my left hand.
steamer471
Nov 2, 2013
860
218
58
Charlotte NC
This one ain't so much hard as awkward. Poor design, 1980 Howard Miller, have to hold the glass upward with one hand while the clock moves around trying to wind it. Can't attach the bottom to the wall because to regulate it there is no front door, have to take it down from the wall, slide a panel up in the back to turn the regulating nut on the pendulum.
J. A. Olson
Dec 21, 2006
5,196
868
WI
No keywind clock should be so hard to wind, you are looking at problems with the spring or not using an adequate key if there are difficulties in winding it. Keys with a thick, wide handle are more ideal for winding clocks with large springs. I speak from experience.
rusty_apache
Apr 18, 2011
30
Alamo city
This format confuses me….
This was not meant to be a new thread.
sorry….
The 1930? Junghans
It hurts my feelings to wind it
The main spring bearing is shot, causing the gears to bind with each brutal turn. Consequently I rarely use it
The Westminster chimes are slightly off pitch so when it strikes it is a minor sounding chord that is so nice and gloomy!
wow
Jun 24, 2008
7,293
1,455
78
Pineville, La. (central La.)
My Seth Thomas Umbria is my hardest to wind. Why? It’s hung too high on the wall to reach. I have to bring in my 7 foot step ladder to reach it.
rusty_apache
Apr 18, 2011
30
Alamo city
sorry….
The 1930? Junghans
Thanks for moving my errant post for me!
brian fisher
Jan 20, 2017
1,821
475
houston, tx
Paillard music box. The spring is scary huge but very safe because of the crank.
View attachment 680463 View attachment 680466
well, on this note, my parents have a Regina music box that plays a disk that is around 30" in diameter. i can't imagine the massive spring winder you would need to take the barrels apart.
you can see one of the spring barrels in this image.
as far as clocks are concerned. both my 13 tube jacques and my 18c Dutch chimer have a 35lb chime weight. its a bit of a struggle to get the weight to the top of the cabinet.
Calvin H. Huynh
Feb 6, 2020
1,781
289
Madison
www.youtube.com
That’s a beautiful music box. You cannot manhandle the spring lol.
JimmyOz
Feb 21, 2008
1,372
476
67
Gold Coast Qld
You can look at it another way, strong springs make you go a bit slower and make sure the click is locked before you adjust your hand.
At the other end of the scale is, easy to wind clocks, I find that around 1 to 2 out of 10 French clock movements need the hole in the tail end of the spring repaired, my theory for this is that the constant ease (speed) of which you can wind them imparts a lot of pressure around the last click and causes fatigue to the hole.
Cheezhead
Dec 30, 2010
277
49
Wisconsin
Wanting to compare the winding torques of two Hermle 340-020 movements, I made a slotted adaptor to connect a Mossberg B-50, 50 inch-lb torque screwdriver's flat blade to the winding key. The max torque observed among the three springs on both clocks was 8 inch-lb. at the end of a wind. Both clock's winding torques were similar with the chime springs needing more torque than the time springs. Gripping the driver's 1-3/16" dia. ruffled/corrugated handle with four fingers and thumb made it very easy to wind the clocks as compared to a winding key, even one with large wings. An added feature was that the felt and seen torque increase past 8"-lbs made obvious that the clock spring was completely wound.
abe
Jan 8, 2009
185
Central PA, USA
Of my three running clocks, Thomas Lister tall case, a Barnes and Bartholomew wooden works clock and a 1929 Sessions Revere banjo clock, the hardest to wind is my Sessions banjo. Reasons: it uses a key not a crank, it is spring not weights and I have to use my left hand. It is located in our kitchen above a set of three steps leading to our stairs. I need to stand on the steps for the correct height but then need to use my left hand. It was even worse before I got my left shoulder replaced. It was so bad my wife would ask what I am doing because she heard me moaning in pain.
5,809
1,014
I've got an Ingraham perpetual calendar (Figure 8) clock in a similar place in the staircase of my house. I'm using a wide wing key to wind the clock with my left hand. Works well for me.
Staff online
181,391
1,582,705
54,791
LSZ
3,130
Swiss Fake by Kent
Top
