The Hammond Special Buffalo N.Y.
Discussion in 'American Pocket Watches' started by seanfitz, Feb 20, 2012.
  1. seanfitz
    seanfitz Registered User
    Feb 20, 2012
    I'm trying to get some information on a pocket watch which belonged to my grandfather, but can't seem to find the name "The Hammond Special" in the encyclopedia. It's a 17 jewel movement # 1020973. In a Philadelphia watch Co silverode case # 805557. My grandfather had ties with America and I'm trying to find the watch's date and place of origin to help with our family history, any help would be appreciated
    Regards Sean.
  2. Jim Haney
    Jim Haney Registered User
    Sep 21, 2002
    5,036
    Working the farm, Garden,horses, goats, chickens,
    Decatur, TN.
    Frank Hmmond was a RR inspector and had a Jewelery store in Buffalo, NY. His watches that he ordered from Hamilton Watch Co, Lancaster, Pa. had his name on the movement or dial or both and his dial usually had a "H' in script under Hamilton on some models.
  3. seanfitz
    Feb 20, 2012
    Thanks for that information Jim, the name Hammond is on the movement and the initials T.H.S. in script on the dial, but no H underneath. Thats a great help. If, as you say the movement is probably Hamilton I can try to find a data-base to tie the # to a date. After surfing through posts on this site I've learnt a little, thanks guys!
    Regards Sean.
  4. John Cote
    John Cote Registered User
    Aug 26, 2000
    3,411
    10
    Photographer
    Midwest USA
    I would love to see photos of this if you could post some. The Serial number you give (1020973) corresponds to a 16 size 23 jewel grade 950 lever set watch made in about 1913. We don't see these 23 jewel watches with private label names all that often, especially at this late date. The 950 is a very high grade watch. It was popular and it is by no means scarce but one with a PL name on the dial and movement is certainly interesting and worth a look. If you need help posting the photos I would be glad to help.
  5. Jim Haney
    Sep 21, 2002
    5,036
    Decatur, TN.
    sean,
    I am afraid that I didn't give you enought information. Frank Hammond also was an agent for other watch companies, besides Hamilton and the watch you have may be Elgin or Illinois, etc.
    As John said we need a picture of the movement to help you with accurate information.
    By now, you get the concept, of private label watches.
  6. JohnL
    JohnL Registered User
    Feb 11, 2001
    I have an 18s watch signed "The Hammond Special", although, mine is a hampden. I'll post pics when i dig it out.
    Its a partial movement only, no dial. :(
  7. seanfitz
    Feb 20, 2012
    Hi John
    I have attached the images you asked for hope this helps.
    Regards Sean
  8. JohnL
    Feb 11, 2001
    Its a Hampden Watch, i have the same watch, minus the dial on mine.
    I'll check my watch when i get it out.
  9. richiec
    richiec Registered User
    Feb 24, 2007
    5,467
    automotive warranty inspector
    Brick, Ocean, NJ
    It is a Model 3, Grade 81 made about 1895, Nearly 17000 of this grade were made in 28 runs but don't know how many were marked Hammond Special.
  10. seanfitz
    Feb 20, 2012
    Thanks for the info Richec, where can I find a movement picture of the model 3 grade 81?. I've found one that looks very similar @ hamilton ball serial numbers & grade discriptions. But that pic puts it as a 924 18 movement
    regards Sean.
  11. RON in PA
    RON in PA Registered User
    May 18, 2005
    1,891
    36
    Retired Neuroscientist
    S.E. PA
    It's not a Hamilton,but rather a Hampden.
  12. Kent
    Kent Registered User
    #12 Kent, Feb 21, 2012
    With all respect to Henry Burgell, I'm not certain that it is a Hampden Watch Co. grade No. 81.
    Based upon the damaskeening pattern, I believe that this is a grade identified in The Hampden Watch Co., NAWCC Special Order Supplement #1, J. Hernick and R. Arnold, NAWCC, Columbia, PA, 1997, as a "3-Ball" grade (not to be confused in any way with the products of the Ball Watch Co.). Pictures of both grades, the No. 81 and the "3-Ball", may be seen on pages 24 and 25 of that book. Of course, the "3-Ball" grade may simply be a fancy version of the grade No. 81.
    The run 1,020,501 - 1,021,000 has some unusual movements. Ed and I have the following in our data base:
    1,020,586 - Probably grade No. 81
    1,020,863 - Probably grade No. 81
    1,020,887 - Railway
    1,020,892 - "The Governor" a Tu-Tone movement
    1,020,973 - Possibly a "3 Ball" grade, "The Hammond Special" - just added due to this thread
    As a reminder, information in our data base is subject to error, either in reporting or in entering data. Until more examples of Railway grade show up with similar serial numbers, I suspect serial number 1,020,887 as being an error.
    JohnL:
    I'm looking forward to seeing the pictures and serial number of your "The Hammond Special".
  13. HenryB
    HenryB Registered User
    Jan 13, 2004
    2,291
    San Antonio
    #13 HenryB, Feb 21, 2012
    From the swirled plate damasking, Possiblities are it is either a 3 Ball (17 Jewel) or a John Hancock (21 Jewel). Since it is 17 Jewel, thus it is a "3 Ball". It is an Open Face Model 3 17 Jewel Movement.
    Interesting-earliest 3 Ball I have seen. The earliest OF 3 Ball I have in the database is 1052001. The earliest HC 3 Ball I have is 1929001.
    This run is full of Special Labels, which makes it difficult to assign a generic grade for all watches, because Special Labels tend to be "Special".
    Very nice movement and not a lot of 3 Balls around. Current Production estimates on 3 Balls are 1500 for the OF (your watch), and 1750 for the HC watch.
    The picture (from Fred Hansen's website- http://www.fhwatch.com ) I attached is a similar 3 Ball, although it is later (1281321)
  14. seanfitz
    Feb 20, 2012
    Thanks for that informative thread Henry & Kent, and everyone involved. I'm still trying to digest all this information. Bet my old grandad is sitting back somewhere with a glass of Three Swallows having a good laugh at the mischief he's created!. Apart from the long needle from the wheel hub to an assembly on the right, thats my watch. My next port of call is a jewellers shop to see if they can get it running.
  15. seanfitz
    Feb 20, 2012
    Sorry I ment left......Doh!
  16. Kent
    That's a pocket watch regulator. Your watch has a Teske regulator while the picture that Henry put up is a later movement and it has a starwheel rack & pinion style regulator.
  17. JohnL
    Feb 11, 2001
    #17 JohnL, Feb 21, 2012
    I checked my FHS, mine is 7 away from this movement that is posted....
  18. Kent
    That's neat!
    Thanks for posting the picture,
  19. Kent
    Reviewing the run again 1,020,501 - 1,021,000, Ed and I have the following in our data base:
    1,020,777 - "The Governor" - which I missed the first time
    1,020,887 - Railway - ???????
    1,020,973 - "3 Ball" grade, "The Hammond Special" - just added due to this thread
    1,020,980 - "3 Ball" grade, "The Hammond Special" - just added due to this thread
    Does anybody have any others from this run to report?
  20. HenryB
    Jan 13, 2004
    2,291
    San Antonio
    No sightings here. I changed the last 100 watches to 3 Ball.
    Just an FYI - the next run 1021000 to 1022000 the database is blank (No observations).
  21. Kent
    Ed and I don't have anything listed in the 1021000 to 1022000 range, but we wouldn't have recorded any Hampden movements below 16-size, or in this era, having less than 17 jewels.
Similar Threads - Hammond Special Buffalo Forum Date
Illinois 60-hour Bunn Special information????? American Pocket Watches Sep 29, 2017
Finally bought one of my dream watches an 18 size Bunn Special American Pocket Watches Sep 19, 2017
Elgin dials marked Elgin Special American Pocket Watches Sep 2, 2017
Appropriate dial for a Bunn Special? American Pocket Watches Aug 23, 2017
Hammond Pocket Watch by Western Watch Co,big size American Pocket Watches May 14, 2012
