Help The Catgut Finally Gave Out...
Discussion in 'Clock Repair' started by fijidad, May 8, 2020.
  1. fijidad
    fijidad Registered User
    Feb 28, 2010
    296
    36
    Escondido, CA
    I have a nice 3-weight Vienna Regulator (or whatever it's called) and noticed one of the weights laying on the bottom of the case...the catgut had broken. I removed all three weights pending a resolution.
    I presume the choices are to replace the catgut in kind, or upgrade to the twisted steel cable. Any suggestions or direction you might have on this would be appreciated.
  2. bruce linde
    bruce linde Technical Admin
    6,535
    734
    oakland, ca.
    hope no damage was done. purists will tell you to replace with catgut.... i'm of the opinion that i'd rather protect my clocks and have piece of mind by using braided nylon cord. i use dark/discrete/darker cords that don't stretch.... probably on the order of .7mm in thickness... from amazon.
    fijidad likes this.
  3. fijidad
    Feb 28, 2010
    296
    36
    Escondido, CA
    Thanks Bruce, I'll look into that. That sounds like a good way to go.
  4. bruce linde
    6,535
    734
    oakland, ca.
    someone asked me privately about this and here's my response... hope it helps.
    i use .8mm in my vienna regulator, .9 or 1.0 in most of my regulators:
    .8, multiple colors
    https://www.amazon.com/Pandahall-Beading-Knotting-Shamballa-Chocolate/dp/B01MYRVHOQ/ref=sr_1_2?dchild=1&keywords=.9mm%2Bnylon%2Bcord%2Bchocolate&qid=1588981500&s=arts-crafts&sr=1-2&th=1
    a good .9
    https://www.amazon.com/Mini-Blind-Cord-0-9-Polyester/dp/B01DMTFI98/ref=sr_1_1?dchild=1&keywords=1mm%2Blift%2Bcord%2Bchocolate&qid=1588981314&sr=8-1&th=1
    higher quality (and price) black 1mm
    https://www.amazon.com/gp/product/B00KX0129U/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    another 1mm
    https://www.amazon.com/Mandala-Crafts-Replacement-Braided-Windows/dp/B01MSEF15Q/ref=sr_1_1_sspa?dchild=1&keywords=1.2mm%2Blift%2Bcord&qid=1588980984&sr=8-1-spons
    for clocks with heavier weights i beef up to 1.2mm (1.5mm can work on tall case clocks but can sometimes be a little thick). i put this one in two 5-tube westminster chimers last year and really like the quality... unfortunately it doesn't seem to be available at the moment:
    i don't have exact specs for you on how much these cords will hold, but when i initially researched it seemed like they would hold 75-100 lbs... minimum. given no rat's nesting (like gut) and no chinese torture metal splinters from frayed metal cords, i've been happy with my choice... purists, be damned. :cool:
  5. Willie X
    Willie X Registered User
    12,774
    983
    #5 Willie X, May 9, 2020
    For the clock you have there, I would start the search at .030", pretty close to what bruce recommended. These published diameters are not very uniform and vary from one manufacturer to another, so expect some trial and error. If the
    Any breaking strength above 25# should be fine.
    Make sure the cordage is solid braid with some room left on the drum when fully wound.
    Metal cable for your clock is 'off the table' in my shop.
  6. Fitzclan
    Fitzclan Registered User
    Jul 20, 2014
    641
    24
    Long Island, New York
    I’m cheap. Before I ditched the mini-blinds, I removed the cord. There is a lot of it in a standard sized one and if you happen to purchase a new one, there is always way too much cord so I save the excess. Works well.
  7. leeinv66
    leeinv66 Moderator
    Mar 31, 2005
    9,929
    211
    Industry Specialist
    Launceston Tasmania
    I use radio dial cord. You can get it in several colours and I prefer it in black. It comes in diameters from .6mm up to 3mm. And, .8mm is my choice for weights around 2 1/2 pound. I have a single weight Vienna Regulator that I strung with it 12 years ago and it is showing no signs of wear or deterioration.
  8. Willie X
    12,774
    983
    #8 Willie X, May 9, 2020
    Those are good examples of 'good cordage'. But, the mini-blind cord will be about 3 times too thick for this clock. Willie X
  9. fijidad
    Feb 28, 2010
    296
    36
    Escondido, CA
    Thanks for the recommendations...I've put the Pandahall corded braid on my "list" at Amazon so will pick it up the next time I order.
  10. Kevin W.
    Kevin W. Registered User
    22,352
    337
    Harold Bain suggested to me long time ago, Spider wire. And thats what i am using in my GB two weight regulator. I wont go back to catgut.
  11. MARK A. BUTTERWORTH
    MARK A. BUTTERWORTH Registered User
    NAWCC Life Member NAWCC Member
    Jul 4, 2009
    2,314
    94
    Diistributor of movements and movement parts.
    Muscatine, Iowa 52761
    Willie X[/QUOTE]
    I agree. If solid braid cord were available at the time these clocks were built, I have no doubt that is what would have have been used. It is far superior to metal in respect to wear and pliability
  12. D.th.munroe
    D.th.munroe Registered User
    Feb 15, 2018
    462
    163
    Full time clock and watchmaker
    BC Canada
    I use natural (gut) badminton racket string on the best ones (other racket strings for larger ones) and when the customer requests gut, but otherwise I use natural colour synthetic racket string was about $15 at a local shop (also on Amazon) for enough to do a few clocks.
    Dan
  13. fijidad
    Feb 28, 2010
    296
    36
    Escondido, CA
    Kevin, what size Spider Wire do you use?
  14. Kevin W.
    22,352
    337
    I am using Stealth, camo braid, 50 pound .
    fijidad likes this.
  15. fijidad
    Feb 28, 2010
    296
    36
    Escondido, CA
    Looking into this option...what gauge do you use? I weighed one of the three weights and it weighs 3.5 pounds.
  16. D.th.munroe
    Feb 15, 2018
    462
    163
    BC Canada
    Roughly 20 gauge I think is .8mm 21 is .7mm and 22 is .6mm although it varies from manufacturers
    The tension on the rackets is 20-30 lbs so strength shouldn't be a problem
    fijidad likes this.
  17. fijidad
    Feb 28, 2010
    296
    36
    Escondido, CA
    Thanks for all the great tips. I went with the synthetic gut used for tennis and badminton rackets. It seems fairly stiff but once I get it in I'll know better. Got this on Amazon for $7.89US for 40 feet. Don't know when I'll get to this, but now I've got no excuses.
  18. fijidad
    Feb 28, 2010
    296
    36
    Escondido, CA
    Meant to include a picture....
    Kevin W. likes this.
