That's Nuts - Lyre Pendulum
Discussion in 'Clock Repair' started by MuensterMann, Nov 2, 2019.
  1. MuensterMann
    MuensterMann Registered User
    Mar 23, 2008
    1,178
    13
    A woman was given a new Howard Miller grandfather clock for her retirement. Some years later the lyre pendulum was coming apart. It issue was that the rating nut was the wrong size and was bigger than the threads. So, someone put tissue as a filler to hold it on - and not sure when this happened. I tried a sample of rating nuts to get the right size, but no luck. The diameter of the thread rod is .125 inches. I tried a 6-32 nut and it is close, but only goes on a few turns and no more. M2.5 and M3 were too small. What else could I try?
    What would be my options and my best option? 1. Find a new pendulum ($100 more or less). 2. Find a nut at the hardware store that is correct size and place it below the original rating nut. 3. Find the correct size rating nut (looked at the suppliers, but didn't see any good possibilities). 4. Purchase a new center rod with rating nut already attached (I did find one of these with correct length ($12) at one supplier).
  2. bangster
    bangster Moderator
    19,283
    328
    Use a wooden bead for a rating nut. Screw it on and it'll adopt the threads. Hey, it worked for me.
  3. Uhralt
    Uhralt Registered User
    3,850
    383
    If the difference is not too much, you could try to close the hole in the rating nut a bit with a hole closing punch.
  4. bruce linde
    bruce linde Technical Admin
    5,648
    519
    oakland, ca.
    hard to tell without photos, but you said you could get a replacement center rod... if you can remove the existing one, maybe you could rethread it to fit a more standard nut?
  5. CameraGuy32
    CameraGuy32 Registered User
    Apr 12, 2019
    49
    11
    A .125 diameter would be a 5-40 thread.
    Jim DuBois likes this.
  6. R&A
    R&A Registered User
    Oct 21, 2008
    4,171
    99
  7. bangster
    bangster Moderator
    19,283
    328
    Wooden bead! Wooden bead!:)
  8. MuensterMann
    Mar 23, 2008
    1,178
    13
    I am wondering why the odd-sized thread in the first place. I say "odd" since it is not common. Maybe it got mixed into the stock at the factory.
    Placing a regular hex nut at the bottom may not work well, since it would be hard to regulate. The rating nut fits differently on a lyre bob compared to a wooded stick bob.
  9. Uhralt
    3,850
    383
    Somebody recommended some time ago to cut a vertical slit into the rating nut from the inside to the outside with a jeweler's saw. That allows to compress the nut a bit, making the opening more narrow.
  10. shutterbug
    40,775
    722
    Bangsters idea might work. The wood would be "tapped" by the threads on the minute hand.
  11. JTD
    JTD Registered User
    Sep 27, 2005
    6,708
    346
    I thought this was about the rating nut. Where would the minute hand come in?
    JTD
  12. JimmyOz
    JimmyOz Registered User
    Feb 21, 2008
    224
    27
    This Thread is enough to drive you Nut's ......
  13. shutterbug
    40,775
    722
    Ooops. I forgot what we were talking about. BUT - the idea is the same. :rolleyes:
  14. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    3,494
    210
    watchmaker
    I see you got a bead on that.
  15. MuensterMann
    Mar 23, 2008
    1,178
    13
    I took the rod to a nut/bolt specialty shop and it seems that the size is close to a 5-40. However, a 5-40 nut would not work properly. The threads were inspected and no deformities were observed. Anyway, odd threading size.
    After taking the pendulum apart, I had access to more of the threaded rod and it turns out that the rating nut I had was the correct size. The threaded portion of the rating nuts was very close to the bottom portion of the nut and thus was not reaching the threaded portion of the rod. So, a little bit of user error on my part - but resolved and working well now! Live and learn. Do and learn.
  16. JTD
    JTD Registered User
    Sep 27, 2005
    6,708
    346
    Perhaps the nut was upside down?
    JTD
  17. MuensterMann
    Mar 23, 2008
    1,178
    13
    No, it was right-side up - as the fit was correct and upside down it would not fit the backside of the bob.
