Test Stands
Discussion in 'General Clock Discussions' started by Gentlehands, Jun 13, 2012.
  1. Gentlehands
    Gentlehands New Member
    May 20, 2012
    I am planning to buy a clock movement test stand and have seen quite a variety. I am wondering if there are reasons or advantages to buy one type over another? I am working on all different types of brass movements (Ansonia, Newhaven, Gilbert, Seth Thomas, etc.) large and small. If possible, I would prefer to buy only one or two to serve for all kinds, instead of one for each and every type. I am also starting to work on tall case clocks and was wondering what works best for these?
  2. Scottie-TX
    Scottie-TX Registered User
    Apr 6, 2004
    936
    Mesquite, TX
    Well, as you supposed there really isn't one fitzall movement stand. Ideally you will have at least two or more; one for short pendulum clocks that you can place on a work surface and a second for tall clocks that will require a floor standing rig. Perhaps even a third or more specifically for cuckoos and roulants. I began with the small aluminum countertop stand and later added a floorstander and roulant holder. .
  3. bkerr
    bkerr Registered User
    Nov 29, 2007
    1,280
    Sales & Marketing Manager
    Canal Fulton,OH
    The pics below are a result of a conversation with a very good friend who has been in the business many years. I work in the welding field so the stand had to be metal. Notice that one side is open for the removal of the pendlum. I also made seat boards for cuckoos, gf's and others. These are all powder coated so the look sharp as well. The one with the cuckoos has eight stations. I have one other design that is a bit smaller. The stands need to be able to be leveled as well. One thing for sure is you want stabilty, a stand that shakes is no good!
  4. soaringjoy
    soaringjoy Registered User
    Feb 12, 2009
    7,238
    20
    I can only second that.
    Every once in a while, you get a movement you have to fiddle around with, because it won't
    fit a stand.
    I've got one for roulants, one for "regular" spring driven pendulum movements and two wall
    brackets for weighters.
  5. Willie X
    Willie X Registered User
    12,015
    699
    GFs need a substantial stand (often called a horse). You can make a great one, capable of holding 4 GF movements, out of a single 2x8x12' and a single 1x4x12'. A table saw, a chop saw (or radial arm saw), and a sabre saw are needed, if you want it to be precisely made. For small clocks there are very simple holders that can be easily made from a few scraps of hardwood. A post clamp style holder was pictured on this list a couple of weeks ago.
    For most small clocks you can simply screw them to a piece of plywood that is attached to a wall or workbench. A hole for the hand-shaft and you can mount front mount movements too. Many clocks can be test run by simply setting them on a couple of equal size blocks of wood.
  6. Willie X
    12,015
    699
    Here are a couple of nice GF clock stands. Prototype #4 is in the background, prototype #5 is in the foreground. They can be made for about 30 bucks each (new material cost). They are both 48" tall. The one in the back has 16" spacing between the uprights; the one in front has a 30" between the uprights. The top rails need to extend 6 to 7" past the uprights left and right. The curved cut-outs at the lower side of the extensions is very important to give you working room. I can send you more info if you wish.
    Raymond Rice likes this.
  7. Gentlehands
    May 20, 2012
    Thank you all for your input. Does anyone have any experience with the bench type, adjustable metal variety?
  8. Willie X
    12,015
    699
    There is a recent thread. Have you searched the topics at the bottom of this page? There are a couple that have been recommended but I don't remember the details.
    Good luck, Willie X
  9. Scottie-TX
    Apr 6, 2004
    936
    Mesquite, TX
    I've used the teststand listed by TIMESAVERS currently as 19996. I've used it for many years and find it adaptable for most shelf and some short drop wall clock movements. The movable arms, adjustable holding lugs, etc. make it very versatile. Roulants can be a problem but it will hold them. If you need a pixture, I'll add that.
  10. Nick Hainis
    Nick Hainis Registered User
    NAWCC Business
    Sep 6, 2019
    7
    Hey Bkerr. Do you have specs for the larger stand? I know a wielder that could help me fabricate.
    Nick
  11. Rockin Ronnie
    Rockin Ronnie Registered User
    Nov 18, 2012
    1,444
    86
    retired educator
    Greenfield, Nova Scotia
