Telechron Electric help needed.
Discussion in 'Electric Horology' started by Barrymac, May 10, 2017.
  1. Barrymac
    Barrymac Registered User
    Sep 8, 2004
    122
    A friend asked me to try to get this going but I really know nothing about these movements. The second hand sometimes moves very slowly and sometimes not at all. I have tried to picture all marks.[​IMG][​IMG][​IMG][​IMG][​IMG]
  2. shutterbug
    34,325
    Your Telechron movement might be replaceable. If not, it will need to be taken apart and rebuilt. Without a lathe, you won't be able to do that yourself. Do a search on Ebay to see if one like yours is available. Be cautious of statements like "untested, for parts", etc.
  3. R. Croswell
    R. Croswell Registered User
    6,639
    23
  4. stewey
    stewey Registered User
    Dec 20, 2012
    974
    Oshawa, Ontario.
  5. JTD
    JTD Registered User
    Sep 27, 2005
    3,942
    19
    You might get more response if you posted this in the Electric Horology section. One of the moderators might move it for you.
    JTD
  6. bangster
    bangster Super Moderator
    16,290
    20
    I'll do it.
    bangster
    moerator
  7. Barrymac
    Sep 8, 2004
    122
    Thanks to all who have answered. One more thing - how do I remove the hour hand? I want to try Stewey's suggestion and also clean the gears. Removing the first 2 hands was easy but I don't see how the hour hand comes off and don't want to damage anything. And thanks, Bangster. I didn't know about that category.
  8. stewey
    Dec 20, 2012
    974
    Oshawa, Ontario.
    #8 stewey, May 11, 2017
    I would think that the hour hand is just pressed on like the others and you should be able to gently pry it off. Take a fork; spread one tine slightly away from another; place a protective piece of paper on the dial; and gently lever the hand off with the spread tines of the fork. Perhaps let a little oil penetrate the hand-shaft around the hand first. I should add that while you're levering, do it in sort of a see-sawing motion so that you don't bend the hand arbor.
  9. Barrymac
    Sep 8, 2004
    122
    Thanks so much, Stewey! I used lighter fluid and spray lubricant. I applied each around the little gear and let them soak in a few times. So far it's running well!
  10. stewey
    Dec 20, 2012
    974
    Oshawa, Ontario.
    Great! Did you get the hour hand off?
Similar Threads - Telechron Electric help Forum Date
General Electric C-16 with Telechron Rotor Electric Horology Mar 29, 2017
General Electric / Telechron plastic gear replacements Electric Horology Nov 15, 2016
Telechron electric Clocks Electric Horology Feb 25, 2016
Telechron electric clock loses an hour a day. Electric Horology Apr 10, 2015
Electric Time - Telechron Collection - On-line Electric Horology Jul 7, 2013
