Tavannes Trench Watch
rleegabe
Oct 4, 2001
544
10
68
Alderwood Manor Washington State
Having a devil of a time finding a mainspring for this watch. Have called Timesavers, Esslinger, McCaws, Daves watches Cas-ker, Cousins in Great Britain, no luck. It measures in Dennison 7x7x12 1/2 inches long, in millimeters it's Width 1.63x thickness 0.19x length 318mm the watch is a Tavannes 13 ligne movement an old trench watch. Serial number 39959. If anyone knows who else I might try would appreciate a response, thanks.
Chris Radek
Apr 13, 2014
817
336
Lincoln, NE, USA
timeguy.com
I suspect it's just wrong. Bestfit shows 13''' tavannes taking 6x11x11.5 (cal 330) and 7x10x13.5 (cal 370) springs.
7 seems too strong for a fully jeweled time-only movement. Bestfit does show 7 strength (7x7x16.5) for some 15''' tavannes movements.
Reactions: rleegabe
Chris Radek
Apr 13, 2014
817
336
Lincoln, NE, USA
timeguy.com
Hold on a second, it can't really measure 0.19 mm thickness!? That's a 7x4 spring. I don't think your numbers make sense, can you say more about how you measured, and maybe show us a picture of the old spring in the barrel?
Reactions: rleegabe
rleegabe
Oct 4, 2001
544
10
68
I used my electronic caliper so it may be off, but I used my Dennison gauge and the spring was 7 wide, 7 in strength and 12 1/2 inches long.
rleegabe
Oct 4, 2001
544
10
68
View attachment 642429 View attachment 642430 View attachment 642431 View attachment 642432 View attachment 642433
Would anyone know the caliber of this movement :???::???::???:
rleegabe
Oct 4, 2001
544
10
68
Saw that to but the spring is only 12 1/2 inches long. I have another movement that is the same so will tear down to compare. Didn't want to because it was serviced before I got it.
gmorse
12,337
2,037
Hi rleegabe,
Go back to first principles; measure the ID of the barrel, the OD of the arbor and the barrel's inside height and plug those figures into the calculators here.
The strength of a spring is proportional to its width and the cube of its thickness, so accurate measurement is essential and a vernier caliper just isn't good enough.
Reactions: rleegabe
Chris Radek
Apr 13, 2014
817
336
Lincoln, NE, USA
timeguy.com
It's completely standard to see springs measured in mm or dennison for the width and strength (thickness) and then inches for the length. I don't know why. I could go over to the drawer and show you 100 springs marked this way, and probably none in all mm.
On some old springs, especially Elgins, they would mark the strength in inches too (4 decimal places), but this is rare today.
I am surprised but pleased when I see a listing with all three numbers in mm. Of course that's the way that makes the most sense today, but to me at least, it's not standard yet. Just flipping through the Cas-ker mainspring catalog, springs are listed primarily in dennison/dennison/inch and sometimes also have mm/mm/inch. No lengths are given in mm. So I guess my advice is be ready to interpret any system. Fortunately you can tell them apart pretty easily. Your watch's spring is not .0037 mm thick, and it's certainly not 11mm thick, nor is it 300 inches long.
One way this gets tricky is a lot of times I see mm and cm confused, so something will explicitly say .115 mm, when they mean 1.15mm. The mainspring list in the Shugart book is full of this kind of mess.
Chris Radek
Apr 13, 2014
817
336
Lincoln, NE, USA
timeguy.com
Wow I've lived here all my life and never noticed that americans use weird measurement systems! Doesn't everyone measure their body weight in bald eagles per oil well? No wait, some people use "stone" for that :emoji_stuck_out_tongue_winking_eye:
I probably rambled on, but my point was, it's good to understand the systems commonly in use if you're looking for a mainspring, so I tried to explain them. All of us in this business have to use suppliers all over the world, old books, old stock, etc etc.
Al J
Jul 21, 2009
673
98
Canada
Conversion chart for anyone who might need it. No idea where I got this from, but have had an electronic copy for years now. I use it often as a lot of the books like Bestfit always list springs in Dennison...
Reactions: rleegabe
gmorse
12,337
2,037
Hi Al,
There's a typo in the worked example at the bottom of this table:
It should read '113.0976 ÷ .2'.
gmorse
12,337
2,037
Hi Al,
You know this isn't "my" document, right? I just use it for the conversion tables...
Yes, I know, I'm just thinking of anyone freshly coming to this subject . . .
164,923
1,435,155
85,880
Augustiner
2,872
