cspinner
- May 9, 2022
- 75
- 21
- 8
- 39
- Country
I would like to use the repivoting attachments in my lathe to center drill a hole to accept the new pivot. See attached reference diagram for what I plan to do. I have to repivot a pallet fork arbor with a <0.15mm pivot that I cannot find a replacement for.
However, I am missing a suitable drill bit that would sit within the hollow spindle/runner from the tailstock. My 8mm Boley has a tailstock that accepts tubes around 6.5+mm OD. The smaller spindle that would then run within that tube has an ID of just over 3mm. There are tungsten PCB drill bits that have a 3.17mm shank. 1) is this shank large enough to attempt to taper? If so, how do I achieve the correct angle? OR 2) can I instead just part it down to fit within the spindle? I’ve read that the drill bit for this application need not be extremely tight.
My lathe did not come with any tailstock attachments for holding collets nor a drill chuck. It is also my understanding that these attachments, especially if purchased aftermarket, wouldn’t be suitable for center drilling when considering the tolerances. I’m at a loss as to how I would shop for one given the strange sizing of my tailstock.
