karlmansson
I've tried out a few different approaches to working at the bench so far. First off I tried to get my hands on a large enough bench that would go high enough. I have a section that is walled off on the same bench though for use with lathe and drill work so I couldn't bring it all the way up.
Then I tried to get a chair that would go really low but that ended up straining my knees and back.
I've looked around to find a good deal for a table top bench and I've seen a few from Esslinger and other places. None of them seem ideal for me though. I also missed out on a used one, an older bench of Swedish make that fetched a hefty price on an online auction.
In the end I decided to try and put one together for myself! Here are a couple of 3D renders of a Sketchup model I made of it. It's 40cm wide excluding the arm rests. I sized it so that an old four cup oiling station that I use will fit inside the grooves at the rear. Including armrests it sits 70cm wide. It will add 15cm in height to you working surface.
The arm rests and tool holder are detachable and held in place with a screw that passes through the wall of the body of the bench and connects with an inside part of the arm rest and tool holder respectively.
If anyone is interested in the model and the plans, let me know and I can share them with you.
I'll start out on the actual building tomorrow and I'll keep posting my progress!
