T. K. Smith, Oskaloosa, IA pocket watch
reels
Newbie
Mar 2, 2017
Im wondering if anyone can help me identify the real manufacturer and type of watch the photograph shows.
The dial is simply marked
"T. K. SMITH"
"OSKALOOSA, IA"
Thanks for any help,
R
Jim Haney
Sep 21, 2002
7,466
2,746
73
Decatur, TN.
reels,
Welcome to the Message Board !.
We can help you if you will post a picture of the movement, so we can see what company made it. It may be European and we can tell you that also with a good picture of the movement. You posted in the Illinois Private Label section and depending on what you have can move your inquiry to the correct area.
reels
Newbie
Mar 2, 2017
Hi here are a few more photos which i hope will help in my search for info.
Its a very well made watch. The case even has springs on the covers. 20180726_191143.jpg 20180726_191230.jpg 20180726_191009.jpg 20180726_191143.jpg 20180726_191230.jpg 20180726_191009.jpg 20180726_191230.jpg
Many thanks,
R.
Jim Haney
Sep 21, 2002
7,466
2,746
73
Decatur, TN.
Can't read the printing on the movement, looks like it says Swiss?
Why don't you tell us what it says?
Looks similar to a Longines movement.
Dave Coatsworth
Senior Administrator
NAWCC Business
Feb 11, 2005
9,078
4,033
Camarillo, CA
www.daveswatchparts.com
It does say "Swiss". Since it is a Swiss movement, I'm going to move your thread over to the European section. I'm sure someone there will be able to ID the movement.
rrwatch
Gibbs Literary Award
NAWCC Star Fellow
Sep 4, 2000
1,496
599
76
Pooler, GA USA
www.antiquewatchmaker.com
I agree with Jim, from the plate layout, hairspring stud and other features, it appears to be a Longines, but knowing the size and the serial number on the movement (not the number on the case) would help.
reels
Newbie
Mar 2, 2017
Thanks guys. Ive been over this watch with a 10x loupe and i can only find the word "SWISS" on the back of movemet. Where else should i look for the SN? Should i remove the 2 screws holding the movement and look somewhere else?
Thanks for all your help.
Jim Haney
Sep 21, 2002
7,466
2,746
73
Decatur, TN.
Maybe you need a better loupe. I can see a serial number on the edge of the plate by the Large ratchet wheel, looks like 509,xxx.
LloydB
Feb 24, 2006
1,875
181
La Crosse, Wisconsin's West Coast
richiec
Feb 24, 2007
7,200
920
69
Brick, Ocean, NJ
On the Rolex shown the bridges curl up, on the OP's, the bridges curl down. It is only 7 jewels as well, doubt it is a Rolex but stranger things have happened.
gmorse
14,557
3,677
Hi reels,
The movements in Rolex pocket watches and early wrist watches were not made by them but were bought in from other manufacturers such as Aegler and Beguelin amongst others. Rolex finished them to their specifications; they didn't start making their own movements until after their first wrist watches were introduced. If the maker can be identified then the serial number may be useful, (as it would be for Longines for instance), but by itself it has no meaning.
reels
Newbie
Mar 2, 2017
Thank you Graham,
Ive measured the diameter of the movement and it is exactly 1.430" .
I dont know what this equates to in euro watch movement sizing but maybe it will help somewhat.
I do know this, its one well made watch and is still running from a winding 2 days ago and it keeps accurate time!
Thanks,
R
gmorse
14,557
3,677
Hi reels,
That equates to 16 lignes or size 8 in Lancashire Gauge. This may well help someone like Ed Ueberall who knows the Longines movements much better than I do.
Jim Haney
Sep 21, 2002
7,466
2,746
73
Decatur, TN.
Did you adjust the regulator? It is showing in the picture adjusted all the way to the right(Slow) and it keeps accurate time in this position?
reels
Newbie
Mar 2, 2017
Hi Jim, yes i moved the regulator from middle position to the slow position in my search for a name.
SERIAL NUMBER FOUND - Yes, gents it appears i do need a new loupe! The SN is right where you said and i hope it sheads light on its identification.
SN is 509086 and ive attached a photo of it. Ive also attached a number on the case which is not the case SN but another number.
Thanks for the help,
reels
Newbie
Mar 2, 2017
With the SN found would someone see if it matches a Longines movement?
Thanks so much,
R.
Jim Haney
Sep 21, 2002
7,466
2,746
73
Decatur, TN.
The 6 digit serial number would put it at 1888 in the Longines serial numbers and your watch is not that old.
I don't see anything like it on eBay under Longines, the 3 finger bridges curl inwards on a Longines and your curve outward.
The cases serial numbers just use the last digits to match them up when assembling them so the numbers you show would match the last digits of the case number, however case numbers don't help any.
Tom McIntyre
Technical Admin
NAWCC Star Fellow
NAWCC Ruby Member
Golden Circle
Aug 24, 2000
85,198
2,937
86
Boston
awco.org
It looks like the Regina private label line of Omega to me, but I do not have any information on them.
177,621
1,556,788
53,633
Leslie
909
3,058
Watch Inspectors by Kent
