I first mentioned this clock in a different--someone else's--thread, but thought I'd give this clock its own post. Someone had asked for a picture of the clock paper, and here it is. Note that the location is Waterberry, not Waterbury.
Here are a few questions that I hope the experienced wood works people might answer. The clock is running fine with a good strong tick although I have not let the clock go the full 30 hours yet, so we'll see. A 3x5 card dated 1974 came with the clock on which are written notes from a repair person. I believe that was when the clock was last looked at. Graphite has been used as a lubricant. It's distributed over the teeth and in the pivots.
The use of graphite--is that a no-no? Should it also be in the pivot holes? These are not bushed; just the wood. Seems to me that the presence of graphite in the pivot holes might lead to excessive wear. I do not plan to run the clock, but if it shouldn't be there, then I want to remove it. Any advice?
I plan to re-attach the clock paper to the backboard. Someone has recommended an acid-free paste that paper conservators use. I will use that. I've noted that there are de-acidifier sprays available to conservators that can be used to treat the paper. Won't remove the brittleness of the paper but will remove the acid content of the paper--or so it's claimed. Has anyone successfully used this sort of product or would he or she recommend something else to de-acidify the paper. Something else might include "do nothing" as the first option.
