Swiza travel alarm battery puzzle
watchwldr940
Nov 26, 2008
399
20
Hello All
I might be in the wrong forum but I figured the watchmakers out there might have seen this one.
How do I access the battery on this little Swiza travel alarm? Any ideas? Thanks! George
watchwldr940
Nov 26, 2008
399
20
Well it kind of appears that if one backs off that screw the stainless steel back would be forced up. The screw is captured by the back and is shaped in such a way as that appears to be the trick. But I have backed it off a fair amount and as I am always reluctant to force things I figured I'd seek the advice of the board contributors here. Maybe I'm just not applying enough pressure to get the job done, but then again maybe I'm wrong in my approach.. George
watchwldr940
Nov 26, 2008
399
20
At the right side is what appears to be just a blind hole. The one at 12:00 in the pic corresponds to the pin that the lid pivots on. I appreciate the input and will gladly answer any other questions! George
watchwldr940
Nov 26, 2008
399
20
I will add that the Swiza website I checked tells how to set their products but not how to change the battery. I can't even identify the model name. I have seen this one listed as the "Manhattan" BUT that appears o be a different, larger clock. Having the proper ID would certainly be a place to start! George
watchwldr940
Nov 26, 2008
399
20
Have you tried gently prising at the 6:00 point?
That's where the screw is? The screw did gain a bit of separation there where I can get a tool in but my concern was, that if backing out the screw didn't pop it off, do I want to use more force?
I'm probably being too timid with it.
My motto:
Don't force it--Get a bigger hammer! George
watchwldr940
Nov 26, 2008
399
20
With the help of a local fellow member of the NAWCC I was able to remove the back. I was just being too timid and by unscrewing the screw in question the back popped off. Thanks for the help and the advice! George
166,982
1,455,099
87,215
AugustaKevin
