Swiss Pocket Watch Identification
PierceA
Nov 12, 2020
15
21
Hello,
I've been passed down a Swiss pocket watch that doesn't say who made the movement. I've been told that it was probably made around 1900 give or take a decade. The movement serial number is 97996 and the case serial number is 484981 that is probably an H. Muhr's Sons case Crown edition. There's a private label inscribed on the dial and movement of "Howes Bros, Clinton Iowa". I've contacted Longines and they said it's most likely not theirs. Jaeger LeCoultre said it's probably not theirs but they can't be sure without going through the archives. Can anyone tell who made the movement?
Thanks,
Pierce
Ethan Lipsig
NAWCC Gold Member
Jan 8, 2006
2,467
2,347
72
Pasadena
I'll stick my neck out: I think it's an Agassiz based on a LeCoultre ebauche.
Reactions: PierceA and Warwian
roughbarked
Dec 2, 2016
6,300
893
Can't find the exact example easily but it certainly does look like an Agassiz.
However, from Ranfft;
hook-lever regulator
ebauche probably Agassiz
Pritchard: Touchon & Cie, Genève, Sécheron, Petit-Sconnex, Carouge;
1901 founded; cooperation with Agassiz, Angelus, Longines, and Wittnauer; since 1921 associated with Wittnauer.
Reactions: PierceA
PierceA
Nov 12, 2020
15
21
Could you tell me a little more about Agassiz? I'd never heard of them until Ethan mentioned them.
Ethan Lipsig
NAWCC Gold Member
Jan 8, 2006
2,467
2,347
72
Pasadena
Rooughbarked, the reference to Touchons in your posting intrigued me because it never occurred to me that piercea's and John's watches might be Touchons. I am still doubtful that they are, but I know a lot more about Touchons than I do about Agassiz. In my personal classification scheme for Touchons, there are Types TO9 and T09A that resembles piercea's OF movement, although there are differences. I have only seen one example of each type. Both were private labels, but one was stamped "Touchon & Co" under the dial. It would be wonderful if pierca or John would look under the dial of their watches to see if the pillar plate is stamped. Search for Types TO9 and TO9A on Touchon Serial Numbers.doc
As I have often said about Swiss watches, many watches signed by, e.g., Company X, were either made by another firm or based on another firm's ebauche. Thus, even if Touchon stamped its name on a few watches like piercea's or John's, that doesn't mean that it made them. Because I have only seen one example of each of Type TO9 and TO9A, there's all the more reason to doubt that Touchon had much to do with their manufacture.
Reactions: roughbarked
PierceA
Nov 12, 2020
15
21
How do you look under the dial? If I only have to unscrew a few screws without taking apart the movement, I'll do it, but I'm no expert in pocket watches and don't really want to mess with the movement.
Chris Radek
Apr 13, 2014
863
366
Lincoln, NE, USA
timeguy.com
Even getting the bezel and glass off and back on without breaking it is difficult on a case like this. I don't recommend any amateur try to take the hands and dial off a watch without being shown how to do it once or twice first, and obtaining the correct tools. Removing hands safely requires special tools.
PierceA
Nov 12, 2020
15
21
I just watched a video of how to take off the dial and I was like "Yeah, I don't feel comfortable doing this"
PierceA
Nov 12, 2020
15
21
Not being much help in identifying the maker, here is a hunter version that I have been trying to ID for years, without much luck..
View attachment 622191 View attachment 622192
I found a very similar movement to ours here (just flipped) that's an Agassiz:
movement number is 106272
Dr. Jon
Dec 14, 2001
6,537
931
New Hampshire
I have a similar one. I ID'd as Touchon after seeing one on-line with their name on it. I took a bit of flak for that. It still think Touchon was involved but the key player was probably Wittnauer. He was the US distributor for Longines, Audemars Piguet, Agassiz and Touchon.
Touchon was close to Wittnauer. They eventuall bough touchon outright and the patent fo Touchon's signature design as done by an American and assigned to Wittnauer. My current theory is that Touchon was set up to use Geneva to finish and adjust watches from outside Geneva, probably Agassiz, and Audemars Piguet but Wittnauer ran the operation. Touchon was set up to do the final set up of high grade movements before export via Wittnauer.
Here is the under dial of my example.
It shows that this watch is set up for US female winding stems for US cases. This and the double sunk dials show this watch was set up for the US market.
167,025
1,455,488
87,253
javalink
