Swinger Quartz
Discussion in 'Clock Repair' started by Denis O Jahn, Apr 10, 2012.
  1. Denis O Jahn
    Denis O Jahn Registered User
    Aug 28, 2000
    264
    Im in need of a coil or a coil assembly #K104A for a CROSA quartz swinger (China) Anyone aware of a parts source?
    TIA
    Denis Jahn
    Visalia, Ca.
  2. shutterbug
    shutterbug Super Moderator
    34,659
    46
    I've got the same issue. I haven't tried it yet, but am considering using the coil and board from a cheap quartz pendulum movement to see if it will work.
  3. Bob Vance
    Bob Vance Registered User
    Feb 24, 2012
    82
    Merritt's sells them.
    make sure your not using energizer batters.
    Bob
  4. Denis O Jahn
    Aug 28, 2000
    264
    Bob and SB: Thanks for the info. Yes Merritts has a ckt board with coil(s) attached, part # 110CB $7.50.
    Thank you for sharing the info!
    Denis
  5. Tinker Dwight
    Tinker Dwight Registered User
    13,680
    Hi
    Whats the issue with energizer batteries cells?
  6. Bob Vance
    Feb 24, 2012
    82
    The negative post is deferent than other battery's . If its a time only clock, it doesn't seem to matter, but, if it has a pendulum, plays music, chimes, or anything more than keep time, some part of it will not work. There's been a lot of quartz clock thrown away because of them. It pains me to say this but the Japanese battery's are slightly longer than American battery's , and they work better in quartz clocks.
    Bob
  7. harold bain
    NAWCC Member Donor
    40,093
    47
    That's typically a problem with Hermle quartz movements. I haven't run into it with any other types of quartz movements.
  8. Tinker Dwight
    13,680
    Haa Thanks
    A mechanical problem.
    There are a number of ways to fix it but much simpler
    to just use a different battery.
    Makes sense
Similar Threads - Swinger Quartz Forum Date
Quartz Movement Help Clock Repair Tuesday at 1:04 PM
Ansonia Swinger Shield Screw Size Clock Repair Nov 10, 2017
Ansonia Swinger off-kilter Clock Repair Jul 27, 2017
Setting up Junghans Swinger Clock not running. Clock Repair May 7, 2017
Front/back swinger hasn't swung for maybe 60+ years Clock Repair Mar 26, 2017
