Swinger losing time
Discussion in 'Clock Repair' started by tickntock1, Sep 12, 2016.
  1. tickntock1
    tickntock1 Registered User
    Feb 27, 2002
    211
    Hello,
    i have a swinger that is losing time. The lower ball is down as far as it can go. Will adjustment of the pendulum that is on the movement in the upper ball change the time keeping? If it does , which way should the bob be moved, up or down?
    thanks in advance,
    Jim
  2. Willie X
    Willie X Registered User
    11,954
    676
    The pendulum needs to go up. If it has two nuts below the bob, the top nut is the rate adjustment nut and the lower nut is to lock the top nut when the clock is keeping good time.
  3. tickntock1
    Feb 27, 2002
    211
    Thank you, that's what I thought
  4. shutterbug
    40,680
    707
    Think of a swinger as an upside down pendulum. It all works opposite of what intuition dictates.
  5. Willie X
    11,954
    676
    Tick,
    I was thinking about a 'free swinger', a common German wall clock?
    Bugs is thinking of a 'swinger', as a not so common statue clock?
    A picture would help.
