Swing in torsion pendulums
Discussion in '400-Day & Atmos' started by cucoclock, Aug 15, 2011.
  1. cucoclock
    cucoclock Registered User
    Jul 17, 2005
    159
    Clocks Repair and Restore
    Santander, Spain
    Hello all,
    I would like to know your opinions about the way torsion pendulums moves when they are regulating a 400 day clock.
    The only movement I would like to see in this kind of pendulum is a rotative movement.
    But, if you look at carefully sometimes the are two movements:
    1) Rotation
    2) Swing
    Obviously the only movement we need in this kind of clocks is the rotative movement.
    One of the reasons of the swing is some oscilation in the building. For example, when the wind blows strongly (in high buildings), this swinging movement appears in the torsion pendulum.
    But sometimes we can observ this swing movement without any external cause.
    Can anyone provide some insight into the cause of this oscillation in the absence of any movement on the clock?.
    Thank you very much in advance.
    Kind regards,
    Miguel
  2. Tony10Clocks
    Tony10Clocks Registered User
    Aug 10, 2010
    1,641
    Northant's
    Hello cucoclock, A couple of reasons could be the balls are not weighted evenly, ( very unlikley unless some has changed the balls, maybe someone has cleaned them and split the casing of the balls and taken out the weight ). Or the centre hook where the block slots in is bent,
    Tony
  3. cucoclock
    Jul 17, 2005
    159
    Santander, Spain
    Hi Tony,
    Thank you for your answer.
    I think you are right, if balls weight is not correct the fork can move laterally the suspension producing swing.
    Kind regards,
    Miguel
  4. John Hubby
    Sep 7, 2000
    12,108
    170
    The Woodlands, TX
    Both of these reasons are correct and will create what I call "pendulum wobble". A third reason is that the suspension spring may not be perfectly centered in the top or bottom blocks, which causes the spring to be distorted under the weight of the pendulum.
  5. shutterbug
    40,705
    713
    Also not yet mentioned is the necessity of a good solid bench, table, etc. to set the clock on. If the table is not stable, the pendulum will surely influence it and get it rocking.
