I'm a complete newvbie. New to SWCC clocks, this site and tinkering with old clocks.
Looking for a model number and possible age.
I was given this clock (images attached) by a friend. Probably picked up at a Ham (Amateur Radio) Fest.
Face diameter is 16". Base diameter is around 19". Has FR302492 stamped on movement. From searching the Internet, I'm guessing it could be a 37SS. Has hole for light which I understand lights during synchronization, so I guess it's a more modern model?
Looks like earlier owner tried to jury rig a battery connection. In the left side of the movement is a capacitor (little round yellow disk in picture). Were they used in these clocks or is this something that was added by someone tinkering? Also, the cut-out at the bottom of the movement is empty. Is there supposed to be a coil of some kind in there, or does this model only use the one coil in the upper right of the movement.
Glass and case are in good condition. Movement appears intact. I want to get an idea what model this is before I try and bring it back to life.
Thanks in advance for all your help!
Fred
Fred
